ms4w 1.5.2 - unable to get mapserv.exe or
php_mapscript_48.dll to work
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Mon May 8 02:26:50 EDT 2006
Try this site:
http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71d
Regards,
Jacob
> -----Original Message-----
> From: Ben Madin [mailto:ben at REMOTEINFORMATION.COM.AU]
> Sent: 8 May 2006 14:14
> To: Delfos, Jacob
> Cc: mapserver-users at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] ms4w 1.5.2 - unable to get
> mapserv.exe or php_mapscript_48.dll to work
> Thanks Jacob,
> I am getting this message :
> mapserv.exe - Unable to locate Component
> This application has failed to start because MSVCR71D.dll was not
> found. Re-installing the application may fix this problem.
> : if I try to run the application.
> I have completely re-installed the ms4w package, but am still
> getting
> this message, so I can only assume that the binaries are being
> compiled with different libraries in them.
> I don't know where to go on this one?
> cheers
> Ben
> Ben Madin
> Remote Information Pty Ltd
> t/f: 08 9192 5535
> m: 0448 887 220
> ben at remoteinformation.com.au
> On 08/05/2006, at 1:22 PM, Delfos, Jacob wrote:
> > Hi Ben,
> > You have to be very careful with the DLL's. The error you
> get probably
> > means php_mapscript_48.dll is tryin to link to a DLL it is not
> > compatible with. Try to use the dependency walker
> > (www.dependencywalker.com) to find out which one it is (execute
> > "depends.exe php_mapscript_48.dll" in a command line window)
> > As I mentioned, the DLL's from MS4W are not compatible with
> those from
> > DMSolutions. Also, certain DLL's must be in the executable path in
> > order
> > for them to work (just the system path may not be sufficient). For
> > example, gdal13.dll and the ER Mapper DLL's (and some
> others) probably
> > have to sit in the same directory as php-cgi.exe.
> > Regards,
> > Jacob
> >> From: UMN MapServer Users List
> >> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ben Madin
> >> Sent: 8 May 2006 13:17
> >> To: MAPSERVER-USERS at LISTS.UMN.EDU
> >> Subject: [UMN_MAPSERVER-USERS] ms4w 1.5.2 - unable to get
> >> I have just downloaded the latest ms4w (1.5.2) and after
> >> installation
> >> (at c:\ms4w\) I get phpinfo() without trouble.
> >> However, when I click on mapserv.exe I get the following message in
> >> the error log :
> >> Premature end of script headers: mapserv.exe, referer : http://
> >> 10.0.1.2/index.phtml
> >> When I follow http://10.0.1.2/phpinfo_mapscript_48.php
> >> I get :
> >> Warning: dl() [function.dl.html]: Unable to load dynamic library '/
> >> ms4w/Apache/php/extensions/php_mapscript_48.dll' - The specified
> >> module could not be found. in C:\ms4w\Apache\htdocs
> >> \phpinfo_mapscript_48.php on line 2
> >> as the library is in this location, I assume that this is a problem
> >> related to Mapserver above.
> >> thank you.
> >> cheers
> >> Ben
> >> Ben Madin
> >> t/f: 08 9192 5535
> >> m: 0448 887 220
