please help: .mdb access problem
Hedwig Matl
matl.hedwig at UZR.AT
Mon May 8 04:44:46 EDT 2006
Hello Jacob!
Thanks for your mail.
I tried this out, but no - it doesn't work.
With best regards
Hedwig
Delfos, Jacob schrieb:
> Hedwig,
> I think you have to put the tablename behind the path, like:
> CONNECTION "c:\ms4w\apps\test2\mdb\Abtenau.mdb,theTable"
> Hope that helps.
> Regards,
> Jacob
>> -----Original Message-----
>> From: UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Hedwig Matl
>> Sent: 8 May 2006 16:12
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] please help: .mdb access problem
>> Hello and thanks for your reply!
>> I edited the path for my message. I use the absolute path,
>> which looks
>> like this (I also tried relative paths):
>> CONNECTIONTYPE OGR
>> CONNECTION "c:\ms4w\apps\test2\mdb\Abtenau.mdb"
>> This is the error I get when I try to open the file with ogrinfo:
>> C:\>ogrinfo c:\ms4w\apps\test2\mdb\Abtenau.mdb
>> FAILURE:
>> Unable to open datasource
>> `c:\ms4w\apps\test2\mdb\Abtenau.mdb' with the
>> following drivers.
>> -> ESRI Shapefile
>> -> MapInfo File
>> -> UK .NTF
>> -> SDTS
>> -> TIGER
>> -> S57
>> -> DGN
>> -> VRT
>> -> AVCBin
>> -> REC
>> -> Memory
>> -> CSV
>> -> GML
>> -> ODBC
>> -> PostgreSQL
>> -> MySQL
>> Thanks a lot for your help
>> Hedwig
>> Frank Warmerdam schrieb:
>>> Hedwig Matl wrote:
>>>> Hello!
>>>> I'm new to mapserver and already somewhat at a loss.
>>>> If I try to access a .mdb file (via map file and ogrinfo) I get
>>>> following error:
>>>> msOGRFileOpen(): OGR error. Open failed for OGR connection
>>>> `c:\..\test.mdb'. File not found or unsupported format.
>>> Hedwig,
>>> Is this the literal error you are seeing, or have you
>> edited the path
>>> out replacing it with ".."? If this is the literal error
>> then it seems
>>> that the path to the file is being constructed improperly.
>> It may be
>>> that mapserver is trying to apply a SHAPEPATH relative
>> path. I would
>>> suggest you use an absolute path tot he file. What does
>> your CONNECTION
>>> string look?
>>> Best regards,
Mag. Hedwig Matl • Forschungsassistentin
Universitätszentrum Rottenmann (UZR)
Technologiepark 2, A-8786 Rottenmann
www.uni-z-rottenmann.at • www.uzr.at
T: +43 (3614) 21021-19
E: matl.hedwig at uzr.at
