please help: .mdb access problem
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Mon May 8 04:20:32 EDT 2006
Hedwig,
I think you have to put the tablename behind the path, like:
CONNECTION "c:\ms4w\apps\test2\mdb\Abtenau.mdb,theTable"
Hope that helps.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Hedwig Matl
> Sent: 8 May 2006 16:12
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] please help: .mdb access problem
> Hello and thanks for your reply!
> I edited the path for my message. I use the absolute path,
> which looks
> like this (I also tried relative paths):
> CONNECTIONTYPE OGR
> CONNECTION "c:\ms4w\apps\test2\mdb\Abtenau.mdb"
> This is the error I get when I try to open the file with ogrinfo:
> C:\>ogrinfo c:\ms4w\apps\test2\mdb\Abtenau.mdb
> FAILURE:
> Unable to open datasource
> `c:\ms4w\apps\test2\mdb\Abtenau.mdb' with the
> following drivers.
> -> ESRI Shapefile
> -> MapInfo File
> -> UK .NTF
> -> SDTS
> -> TIGER
> -> S57
> -> DGN
> -> VRT
> -> AVCBin
> -> REC
> -> Memory
> -> CSV
> -> GML
> -> ODBC
> -> PostgreSQL
> -> MySQL
> Thanks a lot for your help
> Hedwig
> Frank Warmerdam schrieb:
> > Hedwig Matl wrote:
> >> Hello!
> >> I'm new to mapserver and already somewhat at a loss.
> >> If I try to access a .mdb file (via map file and ogrinfo) I get
> >> following error:
> >> msOGRFileOpen(): OGR error. Open failed for OGR connection
> >> `c:\..\test.mdb'. File not found or unsupported format.
> > Hedwig,
> > Is this the literal error you are seeing, or have you
> edited the path
> > out replacing it with ".."? If this is the literal error
> then it seems
> > that the path to the file is being constructed improperly.
> It may be
> > that mapserver is trying to apply a SHAPEPATH relative
> path. I would
> > suggest you use an absolute path tot he file. What does
> your CONNECTION
> > string look?
> > Best regards,
