please help: .mdb access problem
Hedwig Matl
matl.hedwig at UZR.AT
Mon May 8 04:11:41 EDT 2006
Hello and thanks for your reply!
I edited the path for my message. I use the absolute path, which looks
like this (I also tried relative paths):
CONNECTIONTYPE OGR
CONNECTION "c:\ms4w\apps\test2\mdb\Abtenau.mdb"
This is the error I get when I try to open the file with ogrinfo:
C:\>ogrinfo c:\ms4w\apps\test2\mdb\Abtenau.mdb
FAILURE:
Unable to open datasource `c:\ms4w\apps\test2\mdb\Abtenau.mdb' with the
following drivers.
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> ODBC
-> PostgreSQL
-> MySQL
Thanks a lot for your help
Hedwig
Frank Warmerdam schrieb:
> Hedwig Matl wrote:
>> Hello!
>> I'm new to mapserver and already somewhat at a loss.
>> If I try to access a .mdb file (via map file and ogrinfo) I get
>> following error:
>> msOGRFileOpen(): OGR error. Open failed for OGR connection
>> `c:\..\test.mdb'. File not found or unsupported format.
> Hedwig,
> Is this the literal error you are seeing, or have you edited the path
> out replacing it with ".."? If this is the literal error then it seems
> that the path to the file is being constructed improperly. It may be
> that mapserver is trying to apply a SHAPEPATH relative path. I would
> suggest you use an absolute path tot he file. What does your CONNECTION
> string look?
> Best regards,
