Help building mapserver with ArcSDE on solaris
Dimitri Chausson
dimitri.chausson at TELEATLAS.COM
Tue May 9 11:08:55 EDT 2006
I am trying to compile the mapserver on Solaris (5.8). I have built
everything (GDAL, GD, GEOS, PROJ..) except the mapserver. I am using the
sources from version 4.8.3. Configure is called the following way:
./configure \
--prefix=$HOME/local/mapserver \
--with-httpd=$HOME/local/bin/httpd \
--without-pdf \
--with-gd=$HOME/local/ \
--with-proj=$HOME/local \
--with-geos=$HOME/local/bin/geos-config \
--with-ogr=$HOME/local/bin/gdal-config \
--with-gdal=$HOME/local/bin/gdal-config \
--with-sde=$HOME/local \
--with-sde-version=90 \
--with-wfs
It looks like the configure still has minor errors. At the end of the
output, I get:
configure: checking HTTPD server (Apache) version...
using user-supplied httpd (/XXX/local/bin/httpd)
awk: syntax error near line 1
awk: bailing out near line 1
/XXX/local/bin/httpd version is Apache/2.2.2 ().
I believe that it is not important, so I proceed calling make. It exits
with errors compiling shp2img (see attachement)
Did someone already have this kind of problem, and what are they due to?
Any help would be greatly appreciated,
Thanks in advance,
Dimitri
gcc -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DHAVE_VSNPRINTF -DUSE_EPPL -DUSE_PROJ -DUSE_WMS_SVR -DUSE_WFS_SVR -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_SDE -DUSE_OGR -DUSE_GDAL -DUSE_GEOS -DUSE_ICONV -I/home/navi2809/mill_pdt/local//include -I/home/navi2809/mill_pdt/local/include -I/home/navi2809/mill_pdt/local/include -I/home/navi2809/mill_pdt/local/stowrep/gdal/include -I/home/navi2809/mill_pdt/local/stowrep/geos/include shp2img.o -L. -lmap -L/home/navi2809/mill_pdt/local//lib -lgd -ljpeg -lfreetype -lpng -L/lib -lz -lXpm -lX11 -liconv -ljpeg -lfreetype -lpng -L/lib -lz -lXpm -lX11 -liconv -L/home/navi2809/mill_pdt/local/lib -lproj -ljpeg -L/home/navi2809/mill_pdt/local/lib -lsde90 -lpe90 -lsg90 -lpthread -lsocket -ldl -L/home/navi2809/mill_pdt/local/stowrep/gdal/lib -lgdal -L/home/navi2809/mill_pdt/local/stowrep/geos/lib -lgeos -liconv -L/lib -lz -lm -lstdc++ -o shp2img
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunHex_skip6F_b_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunIex_throw6Fpvpkn0AQstatic_type_info_pF1_v_v_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunIex_alloc6FI_pv_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunKex_rethrow6F_v_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunSregister_exit_code6FpG_v_v_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1c2K6Fpv_v_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunKpure_error6F_v_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1c2k6Fpv_v_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunGex_get6F_pv_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `c::c(n6, (int0_t))'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunKvector_del6FpvIpF1_v_1_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunIex_clean6F_v_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunKvector_new6FpvIIpF1_vp2_1_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunMex_rethrow_q6F_v_'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `c::c(N6, (int0_t))'
/home/navi2809/mill_pdt/local//lib/libsde90.so: undefined reference to `__1cG__CrunKvector_con6FpvIIpF1_vp2_v_'
collect2: ld a retourné 1 code d'état d'exécution
make: *** [shp2img] Error 1
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060509/ecc25e40/dimitri.chausson.vcf
