asp.net2 and mapserv cgi
Piero Cavalieri
piero.cavalieri at GMAIL.COM
Wed May 10 03:42:55 EDT 2006
mapserv –v give corret output. I also tried to use binaries which I was
using on a functional installation, and have the same result. In the past
never had this kind of output. I suppose 2.0 installation changed some
things in SO, because I don't have any more same windows to configure
permissions. For example right click on mapserv.exe, in the past I was able
to fine tune users permissions, now I don't.
P.
Tamas Szekeres ha scritto:
Piero,
Do you really think if it is an ASP.NET issue?
Can you run „mapserv –v" within the cgi directory.
Tamas
*From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
Behalf Of *Piero Cavalieri
*Sent:* Tuesday, May 09, 2006 6:42 PM
*To:* MAPSERVER-USERS at LISTS.UMN.EDU
*Subject:* [UMN_MAPSERVER-USERS] asp.net2 and mapserv cgi
Hi all,
I have new machine on which I installed .net 2.
When doing http request to cgi I have the following response:
"MZ@!L! This program cannot be run in DOS mode"
I worked with mapserv cgi on Win2000, XP, 2003, all with .NET1.1, and never
problems.
I suppose it's IIS new permissions policy, but I didn't find answers. Does
anyone experienced this ?
Thanks in advance,
Piero
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060510/c133d4dc/attachment.html
