asp.net2 and mapserv cgi
Piero Cavalieri
piero.cavalieri at GMAIL.COM
Wed May 10 05:46:15 EDT 2006
Processor is AMD 64bit (SO 32 bit). Could be this an issue ?
P.
Piero Cavalieri ha scritto:
mapserv –v give corret output. I also tried to use binaries which I was
using on a functional installation, and have the same result. In the past
never had this kind of output. I suppose 2.0 installation changed some
things in SO, because I don't have any more same windows to configure
permissions. For example right click on mapserv.exe, in the past I was able
to fine tune users permissions, now I don't.
P.
Tamas Szekeres ha scritto:
Piero,
Do you really think if it is an ASP.NET <http://asp.net/> issue?
Can you run „mapserv –v" within the cgi directory.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060510/c5cb57ae/attachment.html
