asp.net2 and mapserv cgi
Tamas Szekeres
szekerest at GMAIL.COM
Wed May 10 11:00:12 EDT 2006
Trying with Apache might be helpful. ms4w is a quick option.
We should exclude if it is solely an IIS issue.
Tamas
2006/5/10, Piero Cavalieri <piero.cavalieri at gmail.com>:
> Processor is AMD 64bit (SO 32 bit). Could be this an issue ?
> P.
> Piero Cavalieri ha scritto:
> mapserv –v give corret output. I also tried to use binaries which I was
> using on a functional installation, and have the same result. In the past
> never had this kind of output. I suppose 2.0 installation changed some
> things in SO, because I don't have any more same windows to configure
> permissions. For example right click on mapserv.exe, in the past I was able
> to fine tune users permissions, now I don't.
> P.
> Tamas Szekeres ha scritto:
> Piero,
> Do you really think if it is an ASP.NET issue?
> Can you run „mapserv –v" within the cgi directory.
