PHP/MapScript msQueryByPoint
Didrik Pinte
dpinte at ITAE.BE
Wed May 10 03:55:12 EDT 2006
Le mardi 09 mai 2006 à 08:53 -0700, DjwStone a écrit :
> Thanks for the tip, Didrik. However, I'm still befogged. My query has
> returned 1 result (according to $mylayer->getNumResults()). I can use
> $mylayer->getResult() to give me a resultCacheMemberObj apparently, but what
> can I do with that? What are these shape, tile, and class indexes?
> Should I be using queryByPoint in the first place?
> I need a cold compress (or a stiff whisky).
> Dave
It will be easier with some code. It's python but should be clear
enough :
if layer.queryByPoint(self.map, map_point, mode, buffer) ==
mapscript.MS_FAILURE:
logging.error('Error while querying the layer')
else:
results = layer.getResults()
feat_atts = []
layer.open()
num_res = results.numresults
logging.debug("Query successful with %u results" % num_res)
# get the headers
headers = []
for j in xrange(layer.numitems):
headers.append(layer.getItem(j))
# get the dataset
for i in xrange(num_res):
att = []
qresult = results.getResult(i)
afeat = layer.getFeature(qresult.shapeindex, qresult.tileindex)
if afeat is not None:
att.append(afeat.getValue(j))
feat_atts.append(att)
qresult = None
layer.close()
The getFeature method gives you the feature, meaning the shapeObj, in
the layer.
I hope this helps
Didrik
Name: not available
Desc: Ceci est une partie de message
=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060510/c6e702f5/attachment.bin
