error FONTSET
B Tuttle
funkbucket at GMAIL.COM
Wed May 10 13:33:12 EDT 2006
Hi-
I am having a similar problem, but I think my fonts are correctly
located and referenced (possibly I am wrong about htis since I keep
getting the error message). I haven't had any responses to my post
yet. All the info is below any chance you know what is wrong with mine
as well?
Hi-
I am new to this and trying to set up my first map server on a linux
box. When I try to use trutype font labels for my legend I get the
following error:
msGetLabelSize(): TrueType Font error. Requested font (courier) not found.
This also occurs if I change the font to say arial:
msGetLabelSize(): TrueType Font error. Requested font (arial) not found.
My legend is as follows:
LEGEND
STATUS on
IMAGECOLOR 230 230 230
LABEL
TYPE truetype
FONT "courier"
COLOR 0 0 0
SIZE 10
ANTIALIAS true
END
END
Commenting out TYPE and FONT and changing SIZE to small gets rid of
the error. I am not sure if this is a typo, permissions, path, or some
other issue. My fontset.txt, and an ls of the font directory and my
map file are below. Any help would be appreciated.
[root at localhost home]# ls /usr/share/fonts/webcore/
andalemo.ttf courbd.ttf georgiai.ttf tahomabd.ttf trebucit.ttf
arialbd.ttf courbi.ttf georgia.ttf tahoma.ttf trebuc.ttf
arialbi.ttf couri.ttf georgiaz.ttf timesbd.ttf verdanab.ttf
ariali.ttf cour.ttf impact.ttf timesbi.ttf verdanai.ttf
arial.ttf fonts.cache-1 l_10646.ttf timesi.ttf verdana.ttf
ariblk.ttf fonts.dir lucon.ttf times.ttf verdanaz.ttf
comicbd.ttf fonts.scale micross.ttf trebucbd.ttf webdings.ttf
comic.ttf georgiab.ttf symbol.ttf trebucbi.ttf wingding.ttf
arial /usr/share/fonts/webcore/arial.ttf
arial-bold /usr/share/fonts/webcore/arialbd.ttf
arial-italic /usr/share/fonts/webcore/ariali.ttf
arial-bold-italic /usr/share/fonts/webcore/arialbi.ttf
arial_black /usr/share/fonts/webcore/ariblk.ttf
comic_sans /usr/share/fonts/webcore/comic.ttf
comic_sans-bold /usr/share/fonts/webcore/comicbd.ttf
courier /usr/share/fonts/webcore/cour.ttf
courier-bold /usr/share/fonts/webcore/courbd.ttf
courier-italic /usr/share/fonts/webcore/couri.ttf
courier-bold-italic /usr/share/fonts/webcore/courbi.ttf
georgia /usr/share/fonts/webcore/georgia.ttf
georgia-bold /usr/share/fonts/webcore/georgiab.ttf
georgia-italic /usr/share/fonts/webcore/georgiai.ttf
georgia-bold-italic /usr/share/fonts/webcore/georgiaz.ttf
impact /usr/share/fonts/webcore/impact.ttf
monotype.com /usr/share/fonts/webcore/monotype.ttf
recreation_symbols /usr/share/fonts/webcore/recreate.ttf
times /usr/share/fonts/webcore/times.ttf
times-bold /usr/share/fonts/webcore/timesbd.ttf
times-italic /usr/share/fonts/webcore/timesi.ttf
times-bold-italic /usr/share/fonts/webcore/timesbi.ttf
trebuchet_ms /usr/share/fonts/webcore/trebuc.ttf
trebuchet_ms-bold /usr/share/fonts/webcore/trebucbd.ttf
trebuchet_ms-italic /usr/share/fonts/webcore/trebucit.ttf
trebuchet_ms-bold-italic /usr/share/fonts/webcore/trebucbi.ttf
verdana /usr/share/fonts/webcore/verdana.ttf
verdana-bold /usr/share/fonts/webcore/verdanab.ttf
verdana-italic /usr/share/fonts/webcore/verdanai.ttf
verdana-bold-italic /usr/share/fonts/webcore/verdanaz.ttf
NAME "AppDesign3"
UNITS meters
SIZE 640 480
IMAGECOLOR 255 255 255
IMAGETYPE png
SHAPEPATH "/data/"
#Bottom left, upper right
EXTENT 139732.562544 4093791.107191 763734.812496 4546455.000230
FONTSET "/usr/local/apache2/htdocs/fontset.txt"
WEB
HEADER "/usr/local/apache2/htdocs/appdesign3_web_header.html"
FOOTER "/usr/local/apache2/htdocs/appdesign3_web_footer.html"
EMPTY "/appdesign3_no_results.html"
TEMPLATE "/usr/local/apache2/htdocs/appdesign3.html"
IMAGEPATH "/usr/local/apache2/htdocs/tmp/"
IMAGEURL "/tmp/"
END
SYMBOL
NAME "triangle"
TYPE vector
POINTS
0 4
2 0
4 4
0 4
END
END
REFERENCE
IMAGE "/data/colorado_ref_map.gif"
SIZE 300 225
STATUS on
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
QUERYMAP
STATUS on
STYLE hilite
COLOR 255 0 0
SIZE 480 320
END
SCALEBAR
LABEL
COLOR 0 0 0
ANTIALIAS true
SIZE small
END
POSITION lr
INTERVALS 5
STATUS embed
SIZE 144 5
STYLE 0
UNITS miles
BACKGROUNDCOLOR 255 255 255
COLOR 0 0 0
OUTLINECOLOR 0 0 0
TRANSPARENT off
END
LEGEND
STATUS on
LABEL
TYPE truetype
FONT "courier"
COLOR 0 0 0
SIZE 10
#SIZE small
ANTIALIAS true
END
END
LAYER
NAME "USGS_Index"
STATUS on
TYPE polygon
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=project1 user=postgres host=localhost port=5432"
DATA "the_geom from usgs_index"
HEADER "/usr/local/apache2/htdocs/appdesign3_index_header.html"
FOOTER "/usr/local/apache2/htdocs/appdesign3_index_footer.html"
TOLERANCE 100
TOLERANCEUNITS meters
LABELCACHE on
LABELITEM 'QUAD_NAME'
LABELMAXSCALE 250000
CLASS
NAME "USGS Index"
TEMPLATE "/usr/local/apache2/htdocs/appdesign3_index_query.html"
STYLE
OUTLINECOLOR 0 255 0
END
LABEL
COLOR 0 255 0
SIZE small
POSITION cc
END # label
END # class
END # layer
LAYER
NAME "Counties"
STATUS on
TYPE polygon
DATA "the_geom from counties"
LABELCACHE on
LABELITEM "CNTY_NAME"
LABELMINSCALE 250000
CLASS
NAME "Counties"
STYLE
SIZE 1
OUTLINECOLOR 0 0 255
END
LABEL
#MINFEATURESIZE auto
COLOR 0 0 255
SIZE small
POSITION cc
END # label
END # class
END # layer
LAYER
NAME "Cities"
STATUS on
TYPE point
DATA "the_geom from cities"
LABELCACHE on
LABELITEM "name"
LABELMAXSCALE 100000
MAXSCALE 1000000
CLASS
STYLE
COLOR 255 0 0
SYMBOL 'triangle'
SIZE 5
END
LABEL
COLOR 250 0 0
SIZE small
POSITION auto
END
END # class
END # layer states
LAYER
NAME "Highways"
STATUS on
TYPE line
DATA "the_geom from highways"
LABELCACHE on
#LABELITEM "ROUTE"
CLASS
NAME "Highways"
STYLE
SIZE 1
COLOR 0 0 0
END
# LABEL
# COLOR 0 0 0
# SIZE small
# END # label
END # class
END # layer
END # mapfile
On 5/10/06, Graham Davis <gdavis at refractions.net> wrote:
> Hello Eduardo,
> One of the fonts that you have listed in your map file is not located
> where you have listed it. In the future, please show us your MAP file
> so that we can better help you.
> Graham Davis
> Refractions Research Inc.
> Eduardo Arévalo wrote:
> > hello: at the time of executing mapfile it leaves the following error
> > msGetLabelSize(): TrueType Font error. Could not find/open font
> > please help
