error FONTSET
Fawcett, David
David.Fawcett at STATE.MN.US
Wed May 10 13:34:42 EDT 2006
Eduardo,
Is there a file called fonts.list in the place that you have specified?
In that file, is there an entry for 'arial-bold'?
Do the file names both in the fonts.list file and in the filesystem match in their use of upper and lowercase?
You may also want to put quotes around "arial-bold" in your FONT entry.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Eduardo Arévalo
Sent: Wednesday, May 10, 2006 12:25 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] error FONTSET
sorry Graham
this mapfile:
MAP
IMAGETYPE PNG
EXTENT -81.328393 -18.351232 -68.653396 -0.038607
SIZE 400 300
SHAPEPATH "/home/postgres/vectores"
IMAGECOLOR 255 255 255
FONTSET "/home/earevalo/mapserver-4.8.3/fonts/fonts.list"
LAYER
NAME Peru_poly
DATA departamentos
STATUS OFF
TYPE POLYGON
CLASSITEM "nomb_dep"
LABELITEM "capital"
CLASS
NAME "departamento selva"
EXPRESSION "UCAYALI"
STYLE
COLOR 232 232 232
END
LABEL
COLOR 132 31 31
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT arial-bold
SIZE 12
ANTIALIAS TRUE
POSITION CL
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
END #FIN LABEL
END
2006/5/10, Graham Davis <gdavis at refractions.net>:
Hello Eduardo,
One of the fonts that you have listed in your map file is not located
where you have listed it. In the future, please show us your MAP file
so that we can better help you.
Graham Davis
Refractions Research Inc.
Eduardo Arévalo wrote:
> hello: at the time of executing mapfile it leaves the following error
> msGetLabelSize(): TrueType Font error. Could not find/open font
> please help
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060510/a9919229/attachment.html
