error FONTSET
Graham Davis
gdavis at REFRACTIONS.NET
Wed May 10 13:35:10 EDT 2006
Thanks Eduardo,
The first thing I would check for your problem, is to ensure the
/home/earevalo/mapserver-4.8.3/fonts/fonts.list file exists in this
place. If it does, see if it has a definition for arial-bold (since
that is the font you are using in this MAP file). Make sure the file
for arial-bold is in the same directory as the fonts.lst file, and make
sure the definition in the fonts.lst file is correct.
Graham Davis
Refractions Research Inc.
gdavis at refractions.net
Eduardo Arévalo wrote:
> sorry Graham
> this mapfile:
> MAP
> IMAGETYPE PNG
> EXTENT -81.328393 -18.351232 -68.653396 -0.038607
> SIZE 400 300
> SHAPEPATH "/home/postgres/vectores"
> IMAGECOLOR 255 255 255
> FONTSET "/home/earevalo/mapserver-4.8.3/fonts/fonts.list"
> LAYER
> NAME Peru_poly
> DATA departamentos
> STATUS OFF
> TYPE POLYGON
> CLASSITEM "nomb_dep"
> LABELITEM "capital"
> CLASS
> NAME "departamento selva"
> EXPRESSION "UCAYALI"
> STYLE
> COLOR 232 232 232
> END
> LABEL
> COLOR 132 31 31
> SHADOWCOLOR 218 218 218
> SHADOWSIZE 2 2
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 12
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END #FIN LABEL
> END
> 2006/5/10, Graham Davis <gdavis at refractions.net
> <mailto:gdavis at refractions.net>>:
> Hello Eduardo,
> One of the fonts that you have listed in your map file is not located
> where you have listed it. In the future, please show us your MAP
> file
> so that we can better help you.
> Graham Davis
> gdavis at refractions.net <mailto:gdavis at refractions.net>
> > hello: at the time of executing mapfile it leaves the following
> error
> > msGetLabelSize(): TrueType Font error. Could not find/open font
> > please help
