error FONTSET
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed May 10 13:39:49 EDT 2006
Does the apache user have permission to access the font file and the ttf
files?
Best regards,
Bart
B Tuttle wrote:
> Hi-
> I am having a similar problem, but I think my fonts are correctly
> located and referenced (possibly I am wrong about htis since I keep
> getting the error message). I haven't had any responses to my post
> yet. All the info is below any chance you know what is wrong with mine
> as well?
> Hi-
> I am new to this and trying to set up my first map server on a linux
> box. When I try to use trutype font labels for my legend I get the
> following error:
> msGetLabelSize(): TrueType Font error. Requested font (courier) not
> found.
> This also occurs if I change the font to say arial:
> msGetLabelSize(): TrueType Font error. Requested font (arial) not found.
> My legend is as follows:
> LEGEND
> STATUS on
> IMAGECOLOR 230 230 230
> LABEL
> TYPE truetype
> FONT "courier"
> COLOR 0 0 0
> SIZE 10
> ANTIALIAS true
> END
> END
> Commenting out TYPE and FONT and changing SIZE to small gets rid of
> the error. I am not sure if this is a typo, permissions, path, or some
> other issue. My fontset.txt, and an ls of the font directory and my
> map file are below. Any help would be appreciated.
> [root at localhost home]# ls /usr/share/fonts/webcore/
> andalemo.ttf courbd.ttf georgiai.ttf tahomabd.ttf trebucit.ttf
> arialbd.ttf courbi.ttf georgia.ttf tahoma.ttf trebuc.ttf
> arialbi.ttf couri.ttf georgiaz.ttf timesbd.ttf verdanab.ttf
> ariali.ttf cour.ttf impact.ttf timesbi.ttf verdanai.ttf
> arial.ttf fonts.cache-1 l_10646.ttf timesi.ttf verdana.ttf
> ariblk.ttf fonts.dir lucon.ttf times.ttf verdanaz.ttf
> comicbd.ttf fonts.scale micross.ttf trebucbd.ttf webdings.ttf
> comic.ttf georgiab.ttf symbol.ttf trebucbi.ttf wingding.ttf
> arial /usr/share/fonts/webcore/arial.ttf
> arial-bold /usr/share/fonts/webcore/arialbd.ttf
> arial-italic /usr/share/fonts/webcore/ariali.ttf
> arial-bold-italic /usr/share/fonts/webcore/arialbi.ttf
> arial_black /usr/share/fonts/webcore/ariblk.ttf
> comic_sans /usr/share/fonts/webcore/comic.ttf
> comic_sans-bold /usr/share/fonts/webcore/comicbd.ttf
> courier /usr/share/fonts/webcore/cour.ttf
> courier-bold /usr/share/fonts/webcore/courbd.ttf
> courier-italic /usr/share/fonts/webcore/couri.ttf
> courier-bold-italic /usr/share/fonts/webcore/courbi.ttf
> georgia /usr/share/fonts/webcore/georgia.ttf
> georgia-bold
> /usr/share/fonts/webcore/georgiab.ttf
> georgia-italic
> /usr/share/fonts/webcore/georgiai.ttf
> georgia-bold-italic
> /usr/share/fonts/webcore/georgiaz.ttf
> impact /usr/share/fonts/webcore/impact.ttf
> monotype.com
> /usr/share/fonts/webcore/monotype.ttf
> recreation_symbols
> /usr/share/fonts/webcore/recreate.ttf
> times /usr/share/fonts/webcore/times.ttf
> times-bold /usr/share/fonts/webcore/timesbd.ttf
> times-italic /usr/share/fonts/webcore/timesi.ttf
> times-bold-italic /usr/share/fonts/webcore/timesbi.ttf
> trebuchet_ms /usr/share/fonts/webcore/trebuc.ttf
> trebuchet_ms-bold
> /usr/share/fonts/webcore/trebucbd.ttf
> trebuchet_ms-italic
> /usr/share/fonts/webcore/trebucit.ttf
> trebuchet_ms-bold-italic
> /usr/share/fonts/webcore/trebucbi.ttf
> verdana /usr/share/fonts/webcore/verdana.ttf
> verdana-bold
> /usr/share/fonts/webcore/verdanab.ttf
> verdana-italic
> /usr/share/fonts/webcore/verdanai.ttf
> verdana-bold-italic
> /usr/share/fonts/webcore/verdanaz.ttf
> NAME "AppDesign3"
> UNITS meters
> SIZE 640 480
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> SHAPEPATH "/data/"
> #Bottom left, upper right
> EXTENT 139732.562544 4093791.107191 763734.812496 4546455.000230
> FONTSET "/usr/local/apache2/htdocs/fontset.txt"
> WEB
> HEADER "/usr/local/apache2/htdocs/appdesign3_web_header.html"
> FOOTER "/usr/local/apache2/htdocs/appdesign3_web_footer.html"
> EMPTY "/appdesign3_no_results.html"
> TEMPLATE "/usr/local/apache2/htdocs/appdesign3.html"
> IMAGEPATH "/usr/local/apache2/htdocs/tmp/"
> IMAGEURL "/tmp/"
> END
> SYMBOL
> NAME "triangle"
> TYPE vector
> POINTS
> 0 4
> 2 0
> 4 4
> 0 4
> END
> END
> REFERENCE
> IMAGE "/data/colorado_ref_map.gif"
> SIZE 300 225
> STATUS on
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> QUERYMAP
> STATUS on
> STYLE hilite
> COLOR 255 0 0
> SIZE 480 320
> END
> SCALEBAR
> LABEL
> COLOR 0 0 0
> ANTIALIAS true
> SIZE small
> END
> POSITION lr
> INTERVALS 5
> STATUS embed
> SIZE 144 5
> STYLE 0
> UNITS miles
> BACKGROUNDCOLOR 255 255 255
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> TRANSPARENT off
> END
> LEGEND
> STATUS on
> LABEL
> TYPE truetype
> FONT "courier"
> COLOR 0 0 0
> SIZE 10
> #SIZE small
> ANTIALIAS true
> END
> END
> LAYER
> NAME "USGS_Index"
> STATUS on
> TYPE polygon
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=project1 user=postgres host=localhost port=5432"
> DATA "the_geom from usgs_index"
> HEADER "/usr/local/apache2/htdocs/appdesign3_index_header.html"
> FOOTER "/usr/local/apache2/htdocs/appdesign3_index_footer.html"
> TOLERANCE 100
> TOLERANCEUNITS meters
> LABELCACHE on
> LABELITEM 'QUAD_NAME'
> LABELMAXSCALE 250000
> CLASS
> NAME "USGS Index"
> TEMPLATE "/usr/local/apache2/htdocs/appdesign3_index_query.html"
> STYLE
> OUTLINECOLOR 0 255 0
> END
> LABEL
> COLOR 0 255 0
> SIZE small
> POSITION cc
> END # label
> END # class
> END # layer
> LAYER
> NAME "Counties"
> STATUS on
> TYPE polygon
> DATA "the_geom from counties"
> LABELCACHE on
> LABELITEM "CNTY_NAME"
> LABELMINSCALE 250000
> CLASS
> NAME "Counties"
> STYLE
> SIZE 1
> OUTLINECOLOR 0 0 255
> END
> LABEL
> #MINFEATURESIZE auto
> COLOR 0 0 255
> SIZE small
> POSITION cc
> END # label
> END # class
> END # layer
> LAYER
> NAME "Cities"
> STATUS on
> TYPE point
> DATA "the_geom from cities"
> LABELCACHE on
> LABELITEM "name"
> LABELMAXSCALE 100000
> MAXSCALE 1000000
> CLASS
> STYLE
> COLOR 255 0 0
> SYMBOL 'triangle'
> SIZE 5
> END
> LABEL
> COLOR 250 0 0
> SIZE small
> POSITION auto
> END
> END # class
> END # layer states
> LAYER
> NAME "Highways"
> STATUS on
> TYPE line
> DATA "the_geom from highways"
> LABELCACHE on
> #LABELITEM "ROUTE"
> CLASS
> NAME "Highways"
> STYLE
> SIZE 1
> COLOR 0 0 0
> END
> # LABEL
> # COLOR 0 0 0
> # SIZE small
> # END # label
> END # class
> END # layer
> END # mapfile
> On 5/10/06, Graham Davis <gdavis at refractions.net> wrote:
>> Hello Eduardo,
>> One of the fonts that you have listed in your map file is not located
>> where you have listed it. In the future, please show us your MAP file
>> so that we can better help you.
>> Graham Davis
>> Refractions Research Inc.
>> Eduardo Arévalo wrote:
>> > hello: at the time of executing mapfile it leaves the following error
>> > msGetLabelSize(): TrueType Font error. Could not find/open font
>> > please help
OSGIS, Open Source GIS
http://www.osgis.nl
