error FONTSET
Graham Davis
gdavis at REFRACTIONS.NET
Wed May 10 13:53:10 EDT 2006
Hi B,
Things look correct in your setup. You might want to try having the
fontset.txt and all the font files in the same directory. I'm not sure
if this is necessary but it is usually how I set things up. Also ensure
the permission settings for the font files allows mapserver to read
them. That is all I can see to try. Hope it helps,
Graham Davis
Refractions Research Inc.
gdavis at refractions.net
B Tuttle wrote:
> Hi-
> I am having a similar problem, but I think my fonts are correctly
> located and referenced (possibly I am wrong about htis since I keep
> getting the error message). I haven't had any responses to my post
> yet. All the info is below any chance you know what is wrong with mine
> as well?
> Hi-
> I am new to this and trying to set up my first map server on a linux
> box. When I try to use trutype font labels for my legend I get the
> following error:
> msGetLabelSize(): TrueType Font error. Requested font (courier) not
> found.
> This also occurs if I change the font to say arial:
> msGetLabelSize(): TrueType Font error. Requested font (arial) not found.
> My legend is as follows:
> LEGEND
> STATUS on
> IMAGECOLOR 230 230 230
> LABEL
> TYPE truetype
> FONT "courier"
> COLOR 0 0 0
> SIZE 10
> ANTIALIAS true
> END
> END
> Commenting out TYPE and FONT and changing SIZE to small gets rid of
> the error. I am not sure if this is a typo, permissions, path, or some
> other issue. My fontset.txt, and an ls of the font directory and my
> map file are below. Any help would be appreciated.
> [root at localhost home]# ls /usr/share/fonts/webcore/
> andalemo.ttf courbd.ttf georgiai.ttf tahomabd.ttf trebucit.ttf
> arialbd.ttf courbi.ttf georgia.ttf tahoma.ttf trebuc.ttf
> arialbi.ttf couri.ttf georgiaz.ttf timesbd.ttf verdanab.ttf
> ariali.ttf cour.ttf impact.ttf timesbi.ttf verdanai.ttf
> arial.ttf fonts.cache-1 l_10646.ttf timesi.ttf verdana.ttf
> ariblk.ttf fonts.dir lucon.ttf times.ttf verdanaz.ttf
> comicbd.ttf fonts.scale micross.ttf trebucbd.ttf webdings.ttf
> comic.ttf georgiab.ttf symbol.ttf trebucbi.ttf wingding.ttf
> arial /usr/share/fonts/webcore/arial.ttf
> arial-bold /usr/share/fonts/webcore/arialbd.ttf
> arial-italic /usr/share/fonts/webcore/ariali.ttf
> arial-bold-italic /usr/share/fonts/webcore/arialbi.ttf
> arial_black /usr/share/fonts/webcore/ariblk.ttf
> comic_sans /usr/share/fonts/webcore/comic.ttf
> comic_sans-bold /usr/share/fonts/webcore/comicbd.ttf
> courier /usr/share/fonts/webcore/cour.ttf
> courier-bold /usr/share/fonts/webcore/courbd.ttf
> courier-italic /usr/share/fonts/webcore/couri.ttf
> courier-bold-italic /usr/share/fonts/webcore/courbi.ttf
> georgia /usr/share/fonts/webcore/georgia.ttf
> georgia-bold
> /usr/share/fonts/webcore/georgiab.ttf
> georgia-italic
> /usr/share/fonts/webcore/georgiai.ttf
> georgia-bold-italic
> /usr/share/fonts/webcore/georgiaz.ttf
> impact /usr/share/fonts/webcore/impact.ttf
> monotype.com
> /usr/share/fonts/webcore/monotype.ttf
> recreation_symbols
> /usr/share/fonts/webcore/recreate.ttf
> times /usr/share/fonts/webcore/times.ttf
> times-bold /usr/share/fonts/webcore/timesbd.ttf
> times-italic /usr/share/fonts/webcore/timesi.ttf
> times-bold-italic /usr/share/fonts/webcore/timesbi.ttf
> trebuchet_ms /usr/share/fonts/webcore/trebuc.ttf
> trebuchet_ms-bold
> /usr/share/fonts/webcore/trebucbd.ttf
> trebuchet_ms-italic
> /usr/share/fonts/webcore/trebucit.ttf
> trebuchet_ms-bold-italic
> /usr/share/fonts/webcore/trebucbi.ttf
> verdana /usr/share/fonts/webcore/verdana.ttf
> verdana-bold
> /usr/share/fonts/webcore/verdanab.ttf
> verdana-italic
> /usr/share/fonts/webcore/verdanai.ttf
> verdana-bold-italic
> /usr/share/fonts/webcore/verdanaz.ttf
> NAME "AppDesign3"
> UNITS meters
> SIZE 640 480
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> SHAPEPATH "/data/"
> #Bottom left, upper right
> EXTENT 139732.562544 4093791.107191 763734.812496 4546455.000230
> FONTSET "/usr/local/apache2/htdocs/fontset.txt"
> WEB
> HEADER "/usr/local/apache2/htdocs/appdesign3_web_header.html"
> FOOTER "/usr/local/apache2/htdocs/appdesign3_web_footer.html"
> EMPTY "/appdesign3_no_results.html"
> TEMPLATE "/usr/local/apache2/htdocs/appdesign3.html"
> IMAGEPATH "/usr/local/apache2/htdocs/tmp/"
> IMAGEURL "/tmp/"
> END
> SYMBOL
> NAME "triangle"
> TYPE vector
> POINTS
> 0 4
> 2 0
> 4 4
> 0 4
> END
> END
> REFERENCE
> IMAGE "/data/colorado_ref_map.gif"
> SIZE 300 225
> STATUS on
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> QUERYMAP
> STATUS on
> STYLE hilite
> COLOR 255 0 0
> SIZE 480 320
> END
> SCALEBAR
> LABEL
> COLOR 0 0 0
> ANTIALIAS true
> SIZE small
> END
> POSITION lr
> INTERVALS 5
> STATUS embed
> SIZE 144 5
> STYLE 0
> UNITS miles
> BACKGROUNDCOLOR 255 255 255
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> TRANSPARENT off
> END
> LEGEND
> STATUS on
> LABEL
> TYPE truetype
> FONT "courier"
> COLOR 0 0 0
> SIZE 10
> #SIZE small
> ANTIALIAS true
> END
> END
> LAYER
> NAME "USGS_Index"
> STATUS on
> TYPE polygon
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=project1 user=postgres host=localhost port=5432"
> DATA "the_geom from usgs_index"
> HEADER "/usr/local/apache2/htdocs/appdesign3_index_header.html"
> FOOTER "/usr/local/apache2/htdocs/appdesign3_index_footer.html"
> TOLERANCE 100
> TOLERANCEUNITS meters
> LABELCACHE on
> LABELITEM 'QUAD_NAME'
> LABELMAXSCALE 250000
> CLASS
> NAME "USGS Index"
> TEMPLATE "/usr/local/apache2/htdocs/appdesign3_index_query.html"
> STYLE
> OUTLINECOLOR 0 255 0
> END
> LABEL
> COLOR 0 255 0
> SIZE small
> POSITION cc
> END # label
> END # class
> END # layer
> LAYER
> NAME "Counties"
> STATUS on
> TYPE polygon
> DATA "the_geom from counties"
> LABELCACHE on
> LABELITEM "CNTY_NAME"
> LABELMINSCALE 250000
> CLASS
> NAME "Counties"
> STYLE
> SIZE 1
> OUTLINECOLOR 0 0 255
> END
> LABEL
> #MINFEATURESIZE auto
> COLOR 0 0 255
> SIZE small
> POSITION cc
> END # label
> END # class
> END # layer
> LAYER
> NAME "Cities"
> STATUS on
> TYPE point
> DATA "the_geom from cities"
> LABELCACHE on
> LABELITEM "name"
> LABELMAXSCALE 100000
> MAXSCALE 1000000
> CLASS
> STYLE
> COLOR 255 0 0
> SYMBOL 'triangle'
> SIZE 5
> END
> LABEL
> COLOR 250 0 0
> SIZE small
> POSITION auto
> END
> END # class
> END # layer states
> LAYER
> NAME "Highways"
> STATUS on
> TYPE line
> DATA "the_geom from highways"
> LABELCACHE on
> #LABELITEM "ROUTE"
> CLASS
> NAME "Highways"
> STYLE
> SIZE 1
> COLOR 0 0 0
> END
> # LABEL
> # COLOR 0 0 0
> # SIZE small
> # END # label
> END # class
> END # layer
> END # mapfile
> On 5/10/06, Graham Davis <gdavis at refractions.net> wrote:
>> Hello Eduardo,
>> One of the fonts that you have listed in your map file is not located
>> where you have listed it. In the future, please show us your MAP file
>> so that we can better help you.
>> Graham Davis
>> Eduardo Arévalo wrote:
>> > hello: at the time of executing mapfile it leaves the following error
>> > msGetLabelSize(): TrueType Font error. Could not find/open font
>> > please help
