error 1 on virtual point layer
Frank Warmerdam
warmerdam at POBOX.COM
Wed May 10 14:37:42 EDT 2006
Mark Adams wrote:
> Hi all,
> I've found references to this problem in the list, but no solution:
> I've got an application developed in our office that uses ODBC
> connections and OVF files to publish several layers from an Oracle
> database. All is working well in our office; however, this week I am
> implementing the app in the client's environment, and mapserver is
> failing on trying to load the virtual layers (no mapserver error, just
> never get a map back).
> Using OGRINFO I can see the data, but I get an error message before the
> results are listed:
> ERROR1: SetAttributeFilter() not supported on ExecuteSQL() results
> I am presuming that this error is also the reason why the layer doesn't
> draw in mapserver.
> Does anyone have any insight as to what this error means?
Mark,
I am guessing you have slightly different versions of OGR in your different
environments. The message means that an SQL result (perhaps using
SrcSQL in the OVF file?) is being constrained with a SetAttributeFilter()
call. But this is not supported and the attribute filter will be ignored.
I believe this was always the case, but there was some recent work to
propagate the errors out properly which may have changed the behavior.
I don't know that this will help you. It is vaguely possible that updating
to GDAL/OGR 1.3.2 will help in this regard as I made a few changes in
the OGR VRT and OGR ODBC drivers to better handle this whole sequence.
Or, that may be what is causing the problems!
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
