Please help - How do I use mapserv with a HTTP proxy server?
Brown, Jeff (C2MS)
jeffrey.brown at NGC.COM
Wed May 10 16:18:15 EDT 2006
I really need some help here!
I found out that I can set an environment variable named http_proxy to
http://<username>:<password>@<proxyhost>:<proxyport>. Once I do this, I
can use wget to access a WFS service without the need for --proxy-user
and --proxy-passwd. However, even after setting this environment
variable and restarting Apache, I still get the same timeout error when
I attempt to retrieve a WFS layer.
How can I set up mapserv to use a proxy server? Or is this an Apache
httpd issue? Without a solution, I won't be able to use MapServer . . .
Thanks!
JAB
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060510/a7942b72/attachment.html
