enable logfile on IIS [2]
Emil Zegers
taatuut at CHELLO.NL
Wed May 10 17:59:03 EDT 2006
Hello Huub,
Logging with MapServer under IIS is possible.
It works with the WEB LOG parameter you described so there is probably a
specific reason on your system causing trouble.
Have you tried putting an empty file 'mapserver.log' in 'd:/temp' before
starting your app?
Have you checked the Windows event log files?
Is the disk 'd:' a 'real disk' disk and not a mapped one? What file system
do you use on 'd:'?
A lot of questions and not much of a clue, I know, but maybe it will help...
Regards,
Emil
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Huub Fleuren
Sent: woensdag 10 mei 2006 23:35
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] enable logfile on IIS [2]
Hi List
Simple question
Is it possible to get a mapserver.log file on a IIS system?
I need it, because the mapserver doesn't handle a sld_url not good on
the production server (iis required) (it works beautifully for the
testserver)
By the way: i don't see any temporary SLD XMLs anymore in
mapserver 4.8.
Are they deleted automatically or not used anymore?
I tried everything again (see my previous mail) with the mapserv in the
latest ms4w.
MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
in the mapfile
MAP
WEB
IMAGEPATH "d:/temp/"
IMAGEURL "/temp/"
log "d:/temp/mapserver.log"
END
DEBUG ON
LAYER
DEBUG ON
END
(the imagePATH and imageURL work, on CONNECTIONTYPE WMS layers)
and:
SET MS_ERRORFILE=d:/temp/mapserver.log
(via My Computer Manage + reboot of the machine)
i tried
ms_errorfile=d:/temp/mapserver.log
ms_errorfile=d:\temp\mapserver.log
I gave the IUSR fullcontrol rights on d:\temp
No mapserver.log what is missing here? Is it possible?
Thanks again for any tips.
Regards, Huub
