Problems with connecting to ESRI geodat abase on Linux
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Thu May 11 09:55:15 EDT 2006
Could this work using an ODBC bridge?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Stuart Eve
Verzonden: donderdag 11 mei 2006 16:01
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] Problems with connecting to ESRI
geodatabase on Linux
Thanks for the reply,
I guess this means at the moment theres no way of accessing geodatabases
on unix? Perhaps I could have a bit more of a play with it - but then I
guess I'll have to delve into figuring out how it all works!!
Can you think of any other way in which to do it - as it would be
incredibly useful for our current system...
Stu
Frank Warmerdam wrote:
> Stuart Eve wrote:
>> Dear All (especially Frank!)
>> We are currently trying to connect to an ESRI 9.1 personal
>> geodatabase from a Suse 10 box.
>> I cannot connect to it via the mapfile, so have tried to use ogrinfo
>> to connect to narrow down the problem. I am getting the following
>> error message when I run 'ogrinfo
>> /srv/www/htdocs/chersonesos/shapefiles/chers_gis.mdb' :
> Stuart,
> While I haven't tried too hard with mdbtools, I have never been
> successful
> using it. I suppose I should try and not register the PGeo driver on
> unix.
> Best regards,
Stuart Eve
L - P : Archaeology
stuarteve at lparchaeology.com
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060511/fc4e21df/attachment.html
