Problems with connecting to ESRI geodatabase on Linux
Stuart Eve
stuarteve at LPARCHAEOLOGY.COM
Thu May 11 10:00:31 EDT 2006
Thanks for the reply,
I guess this means at the moment theres no way of accessing geodatabases
on unix? Perhaps I could have a bit more of a play with it - but then I
guess I'll have to delve into figuring out how it all works!!
Can you think of any other way in which to do it - as it would be
incredibly useful for our current system...
Stu
Frank Warmerdam wrote:
> Stuart Eve wrote:
>> Dear All (especially Frank!)
>> We are currently trying to connect to an ESRI 9.1 personal
>> geodatabase from a Suse 10 box.
>> I cannot connect to it via the mapfile, so have tried to use ogrinfo
>> to connect to narrow down the problem. I am getting the following
>> error message when I run 'ogrinfo
>> /srv/www/htdocs/chersonesos/shapefiles/chers_gis.mdb' :
> Stuart,
> While I haven't tried too hard with mdbtools, I have never been
> successful
> using it. I suppose I should try and not register the PGeo driver on
> unix.
> Best regards,
Stuart Eve
L - P : Archaeology
stuarteve at lparchaeology.com
