Problems with connecting to ESRI geodat abase on Linux
Stuart Eve
stuarteve at LPARCHAEOLOGY.COM
Thu May 11 11:43:16 EDT 2006
I'm not really sure how to do that....
At the moment I am deep within the code trying to recompile it so that
it looks at the right driver - I'll let you know how I get on!
Stu
Eijnden, B. van den (Bart) wrote:
> Could this work using an ODBC bridge?
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> Van: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Stuart Eve
> Verzonden: donderdag 11 mei 2006 16:01
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: Re: [UMN_MAPSERVER-USERS] Problems with connecting to ESRI
> geodatabase on Linux
> Thanks for the reply,
> I guess this means at the moment theres no way of accessing geodatabases
> on unix? Perhaps I could have a bit more of a play with it - but then I
> guess I'll have to delve into figuring out how it all works!!
> Can you think of any other way in which to do it - as it would be
> incredibly useful for our current system...
> Stu
> Frank Warmerdam wrote:
> > Stuart Eve wrote:
> >> Dear All (especially Frank!)
> >> We are currently trying to connect to an ESRI 9.1 personal
> >> geodatabase from a Suse 10 box.
> >> I cannot connect to it via the mapfile, so have tried to use ogrinfo
> >> to connect to narrow down the problem. I am getting the following
> >> error message when I run 'ogrinfo
> >> /srv/www/htdocs/chersonesos/shapefiles/chers_gis.mdb' :
> > Stuart,
> > While I haven't tried too hard with mdbtools, I have never been
> > successful
> > using it. I suppose I should try and not register the PGeo driver on
> > unix.
> > Best regards,
> Stuart Eve
> L - P : Archaeology
> stuarteve at lparchaeology.com
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen. This
> message shall not constitute any rights or obligations. This message
> is intended solely for the addressee. If you have received this
> message in error, please delete it and notify the sender immediately.
> When in doubt whether this message is correct or complete, please
> contact the sender.
Stuart Eve
L - P : Archaeology
