asp.net2 and mapserv cgi
Tamas Szekeres
szekerest at GMAIL.COM
Fri May 12 08:33:16 EDT 2006
I have available AMD Athlon 64 X2 based hardware at the firm, but I have
only suse 10 (64 bit) installed for now.
Which OS are you using?
It may not be an IIS issue but I am not perfectly sure about it.
Tamas
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Piero Cavalieri
Sent: Friday, May 12, 2006 9:28 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] asp.net2 and mapserv cgi
It's not IIS issue. I installed .net 2 on a win 32bit and have no problem.
I' ll try also ms4w, however in the meanwhile, is there anyone using
mapserver cgi on 64 bit platform ?
Piero
Tamas Szekeres ha scritto:
Trying with Apache might be helpful. ms4w is a quick option.
We should exclude if it is solely an IIS issue.
Tamas
2006/5/10, Piero Cavalieri <HYPERLINK
"mailto:piero.cavalieri at gmail.com"piero.cavalieri at gmail.com>:
Processor is AMD 64bit (SO 32 bit). Could be this an issue ?
P.
Piero Cavalieri ha scritto:
mapserv -v give corret output. I also tried to use binaries which I was
using on a functional installation, and have the same result. In the past
never had this kind of output. I suppose 2.0 installation changed some
things in SO, because I don't have any more same windows to configure
permissions. For example right click on mapserv.exe, in the past I was able
to fine tune users permissions, now I don't.
P.
Piero,
Do you really think if it is an HYPERLINK "http://ASP.NET"ASP.NET issue?
Can you run "mapserv -v" within the cgi directory.
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.392 / Virus Database: 268.5.6/337 - Release Date: 2006.05.11.
No virus found in this outgoing message.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060512/920de18a/attachment.html
