asp.net2 and mapserv cgi
Piero Cavalieri
piero.cavalieri at GMAIL.COM
Fri May 12 09:03:51 EDT 2006
I have itasca demo running on MS4W on this AMD 64bit mobile and installed
.NET2 on 32 bit Desktop and my application is still running.
So maybe I've done something wrong installing libraries here.
Thanks for the moment.
Piero
Tamas Szekeres ha scritto:
I have available AMD Athlon 64 X2 based hardware at the firm, but I have
only suse 10 (64 bit) installed for now.
Which OS are you using?
It may not be an IIS issue but I am not perfectly sure about it.
Tamas
*From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
Behalf Of *Piero Cavalieri
*Sent:* Friday, May 12, 2006 9:28 AM
*To:* MAPSERVER-USERS at LISTS.UMN.EDU
*Subject:* Re: [UMN_MAPSERVER-USERS] asp.net2 and mapserv cgi
It's not IIS issue. I installed .net 2 on a win 32bit and have no problem.
I' ll try also ms4w, however in the meanwhile, is there anyone using
mapserver cgi on 64 bit platform ?
Piero
Trying with Apache might be helpful. ms4w is a quick option.
We should exclude if it is solely an IIS issue.
Tamas
2006/5/10, Piero Cavalieri <piero.cavalieri at gmail.com>:
Processor is AMD 64bit (SO 32 bit). Could be this an issue ?
P.
Piero Cavalieri ha scritto:
mapserv –v give corret output. I also tried to use binaries which I was
using on a functional installation, and have the same result. In the past
never had this kind of output. I suppose 2.0 installation changed some
things in SO, because I don't have any more same windows to configure
permissions. For example right click on mapserv.exe, in the past I was able
to fine tune users permissions, now I don't.
P.
Piero,
Do you really think if it is an ASP.NET <http://asp.net/> issue?
Can you run „mapserv –v" within the cgi directory.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060512/dcc839d1/attachment.html
