epsg updated database
Vincent J. Troisi
Vincent.Troisi at COLORADO.EDU
Fri May 12 11:21:01 EDT 2006
...and the projection code is in the proj-5 beta distribution.
Vince
Vincent J. Troisi wrote:
> Thanks Frank.
> I'll download the beta distribution and review the
> contents.
> Vince
>>> I have imagery in a polar stereographic projection. However,
>>> the latitude of standard parallel is 71 degrees, not 90 degrees.
>>> I noticed that epsg code 3031 defines the projection used
>>> for the imagery. This code exist in the epsg database but not
>>> in the proj-4.4.9 distribution. Are there any plans to update
>>> the epsg code file the proj-4 distribution? And, if so, will
>>> mapserver support the projection?
>> Vince,
>> You might look at PROJ 4.5.0 beta1 which has an updated epsg translation
>> file. I see EPSG has released a new database since I prepared that so
>> I'm already lagging again before even having released PROJ 4.5.0!
>> Best regards,
