epsg updated database
Vincent J. Troisi
Vincent.Troisi at COLORADO.EDU
Fri May 12 11:16:54 EDT 2006
Thanks Frank.
I'll download the beta distribution and review the
contents.
Vince
Frank Warmerdam wrote:
> Vincent J. Troisi wrote:
>> I have imagery in a polar stereographic projection. However,
>> the latitude of standard parallel is 71 degrees, not 90 degrees.
>> I noticed that epsg code 3031 defines the projection used
>> for the imagery. This code exist in the epsg database but not
>> in the proj-4.4.9 distribution. Are there any plans to update
>> the epsg code file the proj-4 distribution? And, if so, will
>> mapserver support the projection?
> Vince,
> You might look at PROJ 4.5.0 beta1 which has an updated epsg translation
> file. I see EPSG has released a new database since I prepared that so
> I'm already lagging again before even having released PROJ 4.5.0!
> Best regards,
