epsg updated database
Frank Warmerdam
warmerdam at POBOX.COM
Fri May 12 10:41:49 EDT 2006
Vincent J. Troisi wrote:
> I have imagery in a polar stereographic projection. However,
> the latitude of standard parallel is 71 degrees, not 90 degrees.
> I noticed that epsg code 3031 defines the projection used
> for the imagery. This code exist in the epsg database but not
> in the proj-4.4.9 distribution. Are there any plans to update
> the epsg code file the proj-4 distribution? And, if so, will
> mapserver support the projection?
Vince,
You might look at PROJ 4.5.0 beta1 which has an updated epsg translation
file. I see EPSG has released a new database since I prepared that so
I'm already lagging again before even having released PROJ 4.5.0!
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
