querybypoint Postgis
Bertsch
clemens.bertschler at GMAIL.COM
Fri May 12 18:39:29 EDT 2006
Hi list
I have a little problem with my application. I have several different
layers(shapefile) furthermore, I have points stored in a PostGIS database.
Every thing works fine except the querying of points in the database, it
shows me always a result but there seems to be nothing in the resultset, at
least the shapeindex of the result is always 1. With points from a shapefile
it works but not for points in PostGIS, i have to add something special?
Maybe the code is not correct, but remind with normal shape files it is
functioning very well.
Thanks anyway,
MAPFILE
LAYER
NAME fincas
TYPE POINT
CONNECTIONTYPE postgis
CONNECTION "dbname=........"
DATA "the_geom FROM (SELECT the_geom from mus where longitudecenter <> 0
AND NAME = 'USAR-0') AS myquery USING UNIQUE the_geom using SRID = -1"
STATUS ON
TOLERANCE 4
METADATA
"DESCRIPTION" "farms"
"RESULT_FIELDS" "f_code"
"TABLE_NAME" "public.mus" # i need that?
END
CLASS
NAME "farms"
TEMPLATE "Dummy"
STYLE
SYMBOL "POINT"
COLOR 192 192 192
SIZE 8
END
END
END
PHP code
$other_point->setXY($x,$y); //x and y are longitude and latitude
$map->querybyPoint($other_point,MS_MULTIPLE,-1);
$layer = $map->getLayerByName('farms');
echo("<br>".$layer->getNumResults()); // i get an result
$layer->open();
$selFields = explode(" ", $layer->getMetaData("RESULT_FIELDS"));
$oRes = $layer->getResult(0);
echo($oRes->tileindex." ".$oRes->shapeindex." ".$oRes->classindex); //
always -1 1 0
if($layer->getNumResults() != 0){
$oShape = $layer->getShape($oRes->tileindex,$oRes->shapeindex);
$ID = $oShape->values['f_code'];
$oShape->free(); //ERROR Call to a member function on a non-object
View this message in context: http://www.nabble.com/querybypoint-Postgis-t1610695.html#a4366731
Sent from the Mapserver - User forum at Nabble.com.
