New Dbox Example
Fawcett, David
David.Fawcett at STATE.MN.US
Mon May 15 17:00:42 EDT 2006
When you hit example.html for the first time, the image is 'broken'.
What happens if you zoom in or pan the image? If you get a valid image,
the issue is most likely with your legend.
You likely have an issue with the location of the provided python or
perl scripts, or you don't have mapscript installed, or you don't have
the paths to the legend executable correct, or you do not have execute
rights set for the scripts....
Or, maybe it is something else....
David.
-----Original Message-----
From: Lawrence Hartpence [mailto:hartpence_gis at co.jasper.ia.us]
Sent: Monday, May 15, 2006 3:51 PM
To: 'Fawcett, David'; MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] New Dbox Example
David,
Thanks for the insight. I changed the backslashes to forward slashes in
the reference to the location to the mapfile and that brought the
scalebars up, but still no image for the main map.
Lawrence
