Variable substutition on CONNECTIONTYPE OGR CONNECTION OGRVRTDatasource (odbc)
    Huub Fleuren
    hfl at HOME.NL
    Sun May 14 09:34:58 PDT 2006
Hi List,
Something changed, but what is it.
I'm using somthing like the following, so a ODBC datasource for a
OGRVRTLayer with variable substitution for the CONNECTION statement.
This works for me since i first used it in mapserv version 4.2.
I compiled gdal 1.3.2 as i normally do; with Xerces, 2.7 this time.
ogrinfo works on a similar ovf file without variable substutution.
If i get something in the log file (this is not always the case) on this
layer it is:
    msDrawMap(): Image handling error. Failed to draw layer named
'kpxy'.
    msOGRFileNextShape(): OGR error. SetAttributeFilter() not supported
on ExecuteSQL() results.
Does this mean that variable substitution is no longer supported here? I
just want to make sure if it still is.
    CONNECTION
                "<OGRVRTDataSource>
                    <OGRVRTLayer name='wwall'>
                        <SrcDataSource>ODBC:admin/admin at db</SrcDataSource>
                        <SrcSQL>SELECT * FROM wwall WHERE (x >
%xmin%) and (x < %xmax%) and (y > %ymin%) and (y < %ymax%)
</SrcSQL>
                        <GeometryType>wkbPoint</GeometryType>
                        <GeometryField encoding='PointFromColumns' x='x'
y='y'/>
                    </OGRVRTLayer>
                </OGRVRTDataSource>"
What is the reason why this construction does not return the selected
points anymore?
Regards, Huub
More information about the MapServer-users
