Variable substutition on CONNECTIONTYPE OGR CONNECTION
OGRVRTDatasource (odbc)
Paul Ramsey
pramsey at REFRACTIONS.NET
Sun May 14 12:43:45 EDT 2006
Huub,
Yes, things changed in later versions (they got more secure!). Check
out the DATAPATTERN clause in the latest mapfile reference manual.
Paul
On 14-May-06, at 9:34 AM, Huub Fleuren wrote:
> Hi List,
> Something changed, but what is it.
> I'm using somthing like the following, so a ODBC datasource for a
> OGRVRTLayer with variable substitution for the CONNECTION statement.
> This works for me since i first used it in mapserv version 4.2.
> I compiled gdal 1.3.2 as i normally do; with Xerces, 2.7 this time.
> ogrinfo works on a similar ovf file without variable substutution.
> If i get something in the log file (this is not always the case) on
> this layer it is:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'kpxy'.
> msOGRFileNextShape(): OGR error. SetAttributeFilter() not
> supported on ExecuteSQL() results.
> Does this mean that variable substitution is no longer supported
> here? I just want to make sure if it still is.
> CONNECTION
> "<OGRVRTDataSource>
> <OGRVRTLayer name='wwall'>
> <SrcDataSource>ODBC:admin/admin at db</
> SrcDataSource>
> <SrcSQL>SELECT * FROM wwall WHERE (x > %
> xmin%) and (x < %xmax%) and (y > %ymin%) and (y < %ymax%)
> </SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding='PointFromColumns'
> x='x' y='y'/>
> </OGRVRTLayer>
> </OGRVRTDataSource>"
> What is the reason why this construction does not return the
> selected points anymore?
> Regards, Huub
