cURL cannot resolve HOSTNAME
Huub Fleuren
hfl at HOME.NL
Mon May 15 07:10:55 EDT 2006
Hi List.
Mapserver 4.8.3 with libcurl-7.15.0 solved this issue (sticking to gdal
1.3.0). The info is in nmake.opt of the 4.8.3 sources.
I got hold of the binary distribution thru john (from buildkit
supposedly), but it cannot be downloaded anymore from curl (7.15.3).
Maybe that goes too.
Regards,Huub
Huub Fleuren wrote:
> Hi List,
> I was wondering what is the recommended version of the cURL library
> for any mapserver build
> http://mapserver.gis.umn.edu/docs/howto/win32_compiling/?searchterm=curl,
> does not provide the information
> i read http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1504#c4
> and i thought, if mapserver isn't adapted to some issue here, what is
> the recommended version?
> The error i got on a server is mapserver 4.8 rc-1 with libcurl.dll
> version 7.11.1.0
> The same library on the same hosting server worked (and still works!)
> for mapserver 4.5
> from mapserver.log
> Thu May 11 15:50:17 2006 - msHTTPExecuteRequests(): HTTP request error.
> HTTP: request failed with curl error code 6 () for
> http://anwb.geodan.nl/sld/91.xml
> that is: http://curl.haxx.se/libcurl/c/libcurl-errors.html
> CURLE_COULDNT_RESOLVE_HOST (6)
> Couldn't resolve host. The given remote host was not resolved.
> Regards, Huub
