getFeature: Results are not correct
Christian Wilmes
C.Wilmes at GMX.DE
Tue May 16 08:54:18 EDT 2006
>Here is a short cut-out from the README_INSTALL where you can see my
version-numbers:
- Apache version 2.0.55
- PHP version 4.4.3-dev
- MapServer 4.8.3 CGI and MapScript (CSharp, Java, PHP,
Python)
- support GD 2.0.33, FreeType 2.1.10, GDAL/OGR 1.3.2,
PROJ, WMS/WFS, Flash, PDF, ECW3.1, PostGIS, GEOS,
libcurl 7.15.0
- mapserver utilities
- gdal/ogr utilities
- proj.4 utilities
- shp2tile utility
- shapelib utilities
- shpdiff utility
- PHP_OGR Extension 1.1.1
- OWTChart 1.2.0
I have not installed some of them separat so that are the versions I'm
using.
I tried out your idea to use CONFIG "OGR_FID" "name_of_your_primary_key",
but the result is still the same. I think posting the newest Mapfile can
never be bad:
MAP
NAME WFS_Server
STATUS ON
WEB
METADATA
"wfs_title" "WFS Server"
"wfs_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?"
"wfs_srs" "EPSG:4326"
END
END
PROJECTION
"init=EPSG:4326"
END
CONFIG "OGR_FID" "id"
LAYER
NAME myWFS
METADATA
"wfs_title" "myWFS"
"gml_include_items" "all"
END
TYPE POINT
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "test.ovf"
PROJECTION
"init=EPSG:4326"
END
DUMP TRUE
END
END
Best Regards
Christian
> --- Ursprüngliche Nachricht ---
> Von: "Eijnden, B. van den (Bart)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
> An: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] getFeature: Results are not correct
> Datum: Tue, 16 May 2006 12:41:58 +0200
> This is most likely because OGR cannot determine a primary key on your
> table. It needs a primary key to operate queries (not for a map display).
> A few questions:
> 1) which version of GDAL?
> 2) which version of Mapserver?
> 3) you can try to use CONFIG "OGR_FID" "name_of_your_primary_key" at your
> MAP object if automatic detection of the primary key fails
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> Van: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Christian Wilmes
> Verzonden: dinsdag 16 mei 2006 12:29
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: [UMN_MAPSERVER-USERS] getFeature: Results are not correct
> Hello,
> first of all sorry for cross posting, but I've got no idea where I have to
> search the mistake so I post it to the GDAL and the Mapserver Mailinglist.
> I'm trying to publish a WFS-Server. The Data (only Point-Data) are in a
> PostgreSQL-Database (no PostGIS!). So the connection to the data is over
> "Virtual Spatial Data". The getCapabilities and DescribeFeatureType
> request
> both work very well. Only the GML-Document getting with the getFeature
> request is not correct. The number of features in the GML-Document are
> correct too every time, but the features are not in the Bounding Box. The
> features in the GML-Document are always the feature which are on the top
> of
> the table they come from. Only the number of feature is correct. The MBR
> (Minimum Boundig Rectangle) on the top of the GML-Document amasingly the
> correct one. So it don't fit to the features in the document. Testing the
> connection with "ogrinfo" and a Boundig-Box is working correct. If I'm
> trying to make a WMS-Server with the same Data and the same OGR-file it
> works very well.
> So here is my Mapfile:
> MAP
> NAME WFS_Server
> STATUS ON
> WEB
> METADATA
> END
> END
> PROJECTION
> "init=EPSG:4326"
> END
> LAYER
> NAME myWFS
> METADATA
> "wfs_title" "myWFS"
> END
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE OGR
> PROJECTION
> "init=EPSG:4326"
> END
> DUMP TRUE
> END
> END
> and the OGR-File test.ovf:
> <OGRVRTDataSource>
> <OGRVRTLayer name="feature">
> <SrcDataSource>PG:host=192.168.5.86 user=cwilmes dbname=rosoapcw
> password=xxx</SrcDataSource>
> <SrcLayer>feature</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>EPSG:4326</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="lat" y="lon"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Here is a URL which I used for testing
> the
> WFS
> getFeature-Request:
http://localhost/cgi-bin/mapserv.exe?&REQUEST=GetFeature&VERSION=1.0.0&SERVI
> CE=WFS&TYPENAME=myWFS&&BBox=9.98,7.98,10,8
> ....and here is the result:
> <?xml version="1.0" encoding="ISO-8859-1"
> <wfs:FeatureCollection
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd
http://127.0.0.1/cgi-bin/mapserv.exe?SERVICE=WFS&VERSION=1.0.0&REQUEST=Descr
> ibeFeatureType&TYPENAME=myWFS&OUTPUTFORMAT=XMLSCHEMA">
> - <gml:boundedBy>
> - <gml:Box srsName="EPSG:4326">
> <gml:coordinates>9.980700,7.984220 9.997500,7.995010</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> - <gml:featureMember>
> - <ms:myWFS>
> - <gml:boundedBy>
> <gml:coordinates>9.682230,7.653260 9.682230,7.653260</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> - <ms:msGeometry>
> - <gml:Point srsName="EPSG:4326">
> <gml:coordinates>9.682230,7.653260</gml:coordinates>
> </gml:Point>
> </ms:msGeometry>
> <ms:id>16</ms:id>
> </ms:myWFS>
> </gml:featureMember>
> - <ms:myWFS>
> - <gml:boundedBy>
> <gml:coordinates>9.768800,7.835870 9.768800,7.835870</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> - <ms:msGeometry>
> <gml:coordinates>9.768800,7.835870</gml:coordinates>
> </gml:Point>
> </ms:msGeometry>
> <ms:id>17</ms:id>
> </ms:myWFS>
> - <ms:myWFS>
> - <gml:boundedBy>
> <gml:coordinates>9.296530,7.426330 9.296530,7.426330</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> - <ms:msGeometry>
> <gml:coordinates>9.296530,7.426330</gml:coordinates>
> </gml:Point>
> </ms:msGeometry>
> <ms:id>18</ms:id>
> </ms:myWFS>
> - <ms:myWFS>
> - <gml:boundedBy>
> <gml:coordinates>9.111500,7.645390 9.111500,7.645390</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> - <ms:msGeometry>
> <gml:coordinates>9.111500,7.645390</gml:coordinates>
> </gml:Point>
> </ms:msGeometry>
> <ms:id>20</ms:id>
> </ms:myWFS>
> </wfs:FeatureCollection>
> I will be very thankful for every idea where the mistake could!
> Please excuse my bad english!
> Best Regards
> Christian
> "Feel free" - 10 GB Mailbox, 100 FreeSMS/Monat ...
> Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
> Mobile Internet - E-Mail und Internet immer und überall!
> GMX zum Mitnehmen: http://www.gmx.net/de/go/pocketweb
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
