getFeature: Results are not correct
Christian Wilmes
C.Wilmes at GMX.DE
Wed May 17 09:58:44 EDT 2006
>Hi All,
now I have testet to set up the WFS with using a MySQL-Database instead of
PostgreSQL. With MySQL everything works fine but with PostgreSQL it doesn't.
A "ogrinfo" request on the commandline works perfect in both cases. With a
WMS its the same, only the WFS which doesn't work with PostgreSQL. Has
anybody an idea what can be the reason for that?
Best Regards
Christian
--- Ursprüngliche Nachricht ---
> Von: Christian Wilmes <C.Wilmes at GMX.DE>
> An: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] getFeature: Results are not correct
> Datum: Tue, 16 May 2006 14:54:18 +0200
> >Here is a short cut-out from the README_INSTALL where you can see my
> version-numbers:
> - Apache version 2.0.55
> - PHP version 4.4.3-dev
> - MapServer 4.8.3 CGI and MapScript (CSharp, Java, PHP,
> Python)
> - support GD 2.0.33, FreeType 2.1.10, GDAL/OGR 1.3.2,
> PROJ, WMS/WFS, Flash, PDF, ECW3.1, PostGIS, GEOS,
> libcurl 7.15.0
> - mapserver utilities
> - gdal/ogr utilities
> - proj.4 utilities
> - shp2tile utility
> - shapelib utilities
> - shpdiff utility
> - PHP_OGR Extension 1.1.1
> - OWTChart 1.2.0
> I have not installed some of them separat so that are the versions I'm
> using.
> I tried out your idea to use CONFIG "OGR_FID" "name_of_your_primary_key",
> but the result is still the same. I think posting the newest Mapfile can
> never be bad:
> MAP
> NAME WFS_Server
> STATUS ON
> WEB
> METADATA
> "wfs_title" "WFS Server"
> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?"
> "wfs_srs" "EPSG:4326"
> END
> END
> PROJECTION
> "init=EPSG:4326"
> END
> CONFIG "OGR_FID" "id"
> LAYER
> NAME myWFS
> METADATA
> "wfs_title" "myWFS"
> "gml_include_items" "all"
> END
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "test.ovf"
> PROJECTION
> "init=EPSG:4326"
> END
> DUMP TRUE
> END
> END
> Best Regards
> Christian
> > Von: "Eijnden, B. van den (Bart)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
> > Datum: Tue, 16 May 2006 12:41:58 +0200
> > This is most likely because OGR cannot determine a primary key on your
> > table. It needs a primary key to operate queries (not for a map
> display).
> > A few questions:
> > 1) which version of GDAL?
> > 2) which version of Mapserver?
> > 3) you can try to use CONFIG "OGR_FID" "name_of_your_primary_key" at
> your
> > MAP object if automatic detection of the primary key fails
> > Best regards,
> > Bart
> > -----Oorspronkelijk bericht-----
> > Van: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Christian Wilmes
> > Verzonden: dinsdag 16 mei 2006 12:29
> > Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> > Onderwerp: [UMN_MAPSERVER-USERS] getFeature: Results are not correct
> > Hello,
> > first of all sorry for cross posting, but I've got no idea where I have
> to
> > search the mistake so I post it to the GDAL and the Mapserver
> Mailinglist.
> > I'm trying to publish a WFS-Server. The Data (only Point-Data) are in a
> > PostgreSQL-Database (no PostGIS!). So the connection to the data is over
> > "Virtual Spatial Data". The getCapabilities and DescribeFeatureType
> > request
> > both work very well. Only the GML-Document getting with the getFeature
> > request is not correct. The number of features in the GML-Document are
> > correct too every time, but the features are not in the Bounding Box.
> The
> > features in the GML-Document are always the feature which are on the top
> > of
> > the table they come from. Only the number of feature is correct. The MBR
> > (Minimum Boundig Rectangle) on the top of the GML-Document amasingly the
> > correct one. So it don't fit to the features in the document. Testing
> the
> > connection with "ogrinfo" and a Boundig-Box is working correct. If I'm
> > trying to make a WMS-Server with the same Data and the same OGR-file it
> > works very well.
> > So here is my Mapfile:
> > MAP
> > NAME WFS_Server
> > STATUS ON
> > WEB
> > METADATA
> > END
> > END
> > PROJECTION
> > "init=EPSG:4326"
> > END
> > LAYER
> > NAME myWFS
> > METADATA
> > "wfs_title" "myWFS"
> > END
> > TYPE POINT
> > STATUS ON
> > CONNECTIONTYPE OGR
> > PROJECTION
> > "init=EPSG:4326"
> > END
> > DUMP TRUE
> > END
> > END
> > and the OGR-File test.ovf:
> > <OGRVRTDataSource>
> > <OGRVRTLayer name="feature">
> > <SrcDataSource>PG:host=192.168.5.86 user=cwilmes dbname=rosoapcw
> > password=xxx</SrcDataSource>
> > <SrcLayer>feature</SrcLayer>
> > <GeometryType>wkbPoint</GeometryType>
> > <LayerSRS>EPSG:4326</LayerSRS>
> > <GeometryField encoding="PointFromColumns" x="lat" y="lon"/>
> > </OGRVRTLayer>
> > </OGRVRTDataSource>
> > Here is a URL which I used for testing
> > the
> > WFS
> > getFeature-Request:
http://localhost/cgi-bin/mapserv.exe?&REQUEST=GetFeature&VERSION=1.0.0&SERVI
> > CE=WFS&TYPENAME=myWFS&&BBox=9.98,7.98,10,8
> > ....and here is the result:
> > <?xml version="1.0" encoding="ISO-8859-1"
> > <wfs:FeatureCollection
> > xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> > xmlns:wfs="http://www.opengis.net/wfs"
> > xmlns:gml="http://www.opengis.net/gml"
> > xmlns:ogc="http://www.opengis.net/ogc"
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> > xsi:schemaLocation="http://www.opengis.net/wfs
> > http://schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd
http://127.0.0.1/cgi-bin/mapserv.exe?SERVICE=WFS&VERSION=1.0.0&REQUEST=Descr
> > ibeFeatureType&TYPENAME=myWFS&OUTPUTFORMAT=XMLSCHEMA">
> > - <gml:boundedBy>
> > - <gml:Box srsName="EPSG:4326">
> > <gml:coordinates>9.980700,7.984220 9.997500,7.995010</gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > - <gml:featureMember>
> > - <ms:myWFS>
> > - <gml:boundedBy>
> > <gml:coordinates>9.682230,7.653260 9.682230,7.653260</gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > - <ms:msGeometry>
> > - <gml:Point srsName="EPSG:4326">
> > <gml:coordinates>9.682230,7.653260</gml:coordinates>
> > </gml:Point>
> > </ms:msGeometry>
> > <ms:id>16</ms:id>
> > </ms:myWFS>
> > </gml:featureMember>
> > - <ms:myWFS>
> > - <gml:boundedBy>
> > <gml:coordinates>9.768800,7.835870 9.768800,7.835870</gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > - <ms:msGeometry>
> > <gml:coordinates>9.768800,7.835870</gml:coordinates>
> > </gml:Point>
> > </ms:msGeometry>
> > <ms:id>17</ms:id>
> > </ms:myWFS>
> > - <ms:myWFS>
> > - <gml:boundedBy>
> > <gml:coordinates>9.296530,7.426330 9.296530,7.426330</gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > - <ms:msGeometry>
> > <gml:coordinates>9.296530,7.426330</gml:coordinates>
> > </gml:Point>
> > </ms:msGeometry>
> > <ms:id>18</ms:id>
> > </ms:myWFS>
> > - <ms:myWFS>
> > - <gml:boundedBy>
> > <gml:coordinates>9.111500,7.645390 9.111500,7.645390</gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > - <ms:msGeometry>
> > <gml:coordinates>9.111500,7.645390</gml:coordinates>
> > </gml:Point>
> > </ms:msGeometry>
> > <ms:id>20</ms:id>
> > </ms:myWFS>
> > </wfs:FeatureCollection>
> > I will be very thankful for every idea where the mistake could!
> > Please excuse my bad english!
> > Best Regards
> > Christian
> > "Feel free" - 10 GB Mailbox, 100 FreeSMS/Monat ...
> > Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
> > Mobile Internet - E-Mail und Internet immer und überall!
> > GMX zum Mitnehmen: http://www.gmx.net/de/go/pocketweb
> > Disclaimer
> > Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> > uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> > hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> > informeren. Wij adviseren u om bij twijfel over de juistheid of de
> > volledigheid van de mail contact met afzender op te nemen.
> > This message shall not constitute any rights or obligations.
> > This message is intended solely for the addressee.
> > If you have received this message in error, please delete it and
> > notify the sender immediately. When in doubt whether this message
> > is correct or complete, please contact the sender.
