question about shp2tile
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed May 17 22:11:00 EDT 2006
Zhonghai Wang wrote:
> Hi folks,
> I have a large shapefile, now I am trying to use shp2tile command to
> slice it into pieces, with -r and -c is ok, but I do not fully
> understand the -q parameter, what does it actually mean? and what number
> should a use for this parameter normally?
> or something like this? -- >shp2tile -q 10000 input_shapefile
> output_shapefile
Hi Zhonghai,
The -r -c option breaks the extents of your shapefile into R x C rows
and columns and then tries to fit the objects into the best tile. I any
tile crosses a tile boundary by 5-10% then it is put into a "supertile"
the could be the same extents as the original shape file. So typically
you will end up with r X c + 1 tiles.
The -q N option splits the extents in half either vertically or
horizontally and then sorts the objects into the 2 halves or put them in
a supertile. Then if the either of the two halves has more than N
objects it is again split in half and this continues until all files
have less than N objects. This can cause some strange effects like tiles
with 1 or a small number of objects and most tiles will have less than N
objects in them. Since this algorithm tends to spatially cluster objects
in a file, there is a good chance that if you need the file that all or
most objects in the file will be used.
I recommend trying numbers like 10,000 and 20,000 as you initial tries.
I think you should probably not use numbers less then 8000, but it is
really up to you to try and measure the results to find what works best
for your data.
-Steve W.
