question about shp2tile
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu May 18 09:44:16 EDT 2006
Zhonghai Wang wrote:
> Hi guys,
> I've tried to make a efficient map layer with the commands shp2tile,
> tile4ms, and shptree, but something seems not right, because MapServer
> can not draw the maps. I've made a test in a seperate folder, and I've
> done the following processes:
> data -- Forests.shp (for a country)
> 1. >shp2tile -r 50 -c 50 Forests.shp Forests_Test.shp
> >>>results for this step: shp, shx, and dbf files, there is no prj file
> for the output file
> >>>error info on the console: failed to create shp Forests_Test.shp -1833
This is likely because you are trying to create 2501 files (50 x 50 + 1)
and they all half to be open at the same time for this mode so you
likely ran into a process file handle limit. Also how many point do you
have in this layer? What is the value of Num_points/2500, this number
should not be smaller than 8000 - 10000.
> 2. >tile4ms ---- get the tileindex.shx, tileindex.shp and tileindex.dbf
> files for the Forests_Test.shp, there is still no prj file for tileindex.shp
> >>>no error messages appear at this step
There are no prj files created. Mapserver does not use them.
> 3. >shptree -- to genetare .qix file for all shapefiles in this subfolder
> >>> results for this step: Forests.qix, Forests_Test.qix, and tileindex.qix
> >>>no error info on the console
> but, only if I set DATA "Forests" in the layer object the map will be
> rendered, others like DATA "Forests_Test" or TTILEINDEX "tileindex"
> TILEITEM "location" do not work, the server simply sends back a blank
> image.
> did I make any mistakes or it really do not work well. (I am using MS4W
> 4.8.1)
> I guess some errors occur when I perform the command shp2tile.
What version of shp2tile are you using?
woodbri at carto:/data/mdata$ ~/dev/shptools/shp2tile -v
$Id: shp2tile.c,v 1.13 2005/12/05 22:38:08 woodbri Exp $
If it does not respond with the Id string above you need to upgrade as
there is a serious crashing bug for point data in the earlier version if
you are using the -q option. It should work for the row col option, just
try to decrease the number of tiles.
Also if you do not have something like R x C files in your directory
then the process failed. For the row col option you can also specify
--no-write to just get a stats report of how the data is put into the tiles.
-Steve
> thanks for any further info.
> zhonghai
> On 5/18/06, *Zhonghai Wang* <zhonghaiw at gmail.com
> <mailto:zhonghaiw at gmail.com>> wrote:
> Hi Bob, Steve,
> thank you very much for all these helpful clues, now I think I've
> got the points of the shp2tile command, it's really a good tool to
> slice shapefile.
> zhonghai
> On 5/18/06, *Stephen Woodbridge* <woodbri at swoodbridge.com
>> Hi folks,
>> I have a large shapefile, now I am trying to use shp2tile
> command to
>> slice it into pieces, with -r and -c is ok, but I do not fully
>> understand the -q parameter, what does it actually mean? and
> what number
>> should a use for this parameter normally?
>> or something like this? -- >shp2tile -q 10000 input_shapefile
>> output_shapefile
> Hi Zhonghai,
> The -r -c option breaks the extents of your shapefile into R x C
> rows
> and columns and then tries to fit the objects into the best
> tile. I any
> tile crosses a tile boundary by 5-10% then it is put into a
> "supertile"
> the could be the same extents as the original shape file. So
> typically
> you will end up with r X c + 1 tiles.
> The -q N option splits the extents in half either vertically or
> horizontally and then sorts the objects into the 2 halves or put
> them in
> a supertile. Then if the either of the two halves has more than N
> objects it is again split in half and this continues until all files
> have less than N objects. This can cause some strange effects
> like tiles
> with 1 or a small number of objects and most tiles will have
> less than N
> objects in them. Since this algorithm tends to spatially cluster
> objects
> in a file, there is a good chance that if you need the file that
> all or
> most objects in the file will be used.
> I recommend trying numbers like 10,000 and 20,000 as you initial
> tries.
> I think you should probably not use numbers less then 8000, but
> it is
> really up to you to try and measure the results to find what
> works best
> for your data.
> -Steve W.
