ogr2ogr reprojection
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Thu May 18 13:41:33 EDT 2006
I cannot make a test right now, nor check the documentation, but if I remember right with ogr2ogr something like -s_srs "epsg:4323" should work if there exists epsg-code for your projection. Similarly -t_srs "epsg: " for the target projection.
-Jukka-
-----Original Message-----
From: UMN MapServer Users List on behalf of Zhonghai Wang
Sent: Thu 18.5.2006 19:54
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] ogr2ogr reprojection
what you have said works fine, but now something is wrong again with the srs
definition, the error messages on the console are:
>>>SRS_Def can be a full WKT definition, or a well known definition, i.e.
epsg:4326 or a file with a WKT definition.
in the call_convert.bat, I defined like this:
call convert.bat boundary.shp COUNTRY_region.shp
call convert.bat forests.shp FOREST_region.shp
and in the convert.bat file:
ogr2ogr -init=world:CH1903 -init=epsg:4326 %1 %2
it seems that the project definition "-init=world:CH1903" is not right, but
I use it also in other mapfiles, and it works well.
anything wrong?
zhonghai
On 5/18/06, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> I'm sorry about not being clear enough. You must manually edit the
> "call_convert.bat" by adding the missing parts, that is "call convert.bat" in the beginning of each row, and target name at the end of the row.
> Redirecting the file list to batch file prototype is only to help you in
> creating the working launching bat-file including all your shapefiles.
> I suggest you to make first make manually a launch file with two or three
> rows only and test with that. When you see that it works you can put all
> your shapefiles on the list.
> Regards,
> -Jukka-
> ________________________________
> Lähettäjä: UMN MapServer Users List puolesta: Zhonghai Wang
> Lähetetty: to 18.5.2006 13:29
> Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
> Aihe: Re: [UMN_MAPSERVER-USERS] ogr2ogr reprojection
> Hi Jukka,
> I've tried what you said, but it doen't work.
> the command "dir /b *.shp>call_convert.bat" just simply writes the file
> path into the call_convert.bat file, and the convert.bat command is never
> be called.
> after performing "dir /b *.shp>call_convert.bat" I get the file path in
> the call_convert.bat instead of call convert.bat destination_1 source_1
> and call convert.bat destination_2 source_2.
> something is wrong?
> thanks
> zhonghai
> Hi,
> Another alternative is to make one batch file (.bat) for the actual
> conversion and call it with parameters from another. Like this
> convert.bat
> ogr2ogr [-all fixed parameters like -s_srs and -t_srs here] %1 %2
> call_convert.bat
> call convert.bat destination_3 source_3
> etc.
> Conversion is started by running "call_convert.bat", and
> "destination_1" and "source_1" will be treated as %1 and %2 by the "
> convert.bat ", respectively.
> To start with call_conver.bat you can first insert all your
> shapefiles there by command
> dir /b *.shp >call_convert.bat
> dir /b /s puts there all shapefiles from subdirectories as well.
> This may be a brutal way but it has some advantages. For example
> you can add some extra commands to "convert.bat" to be executed after
> each conversion. This way I use to make log files with time stamps about
> raster file batch conversions.
> Regards,
> -Jukka Rahkonen-
> Lähettäjä: UMN MapServer Users List puolesta: Jelmer Baas
> Lähetetty: to 18.5.2006 8:17
> Zhonghai Wang wrote:
> > Hi,
> > I've tried with this batch command, but I failed, because I don't
> know
> > how to specify the -s_srs and -t_srs parameters, should it be
> something
> > like this?
> >> for %a in (*.shp) do ogr2ogr.exe %a -init=epsg:4326
> -init=world:CH1903
> > **init=world:CH1903 is for switzerland, and I am sure that this
> > projection code is right.
> yeah, this should do it. Sorry for my short last response though.
> This should execute
> ogr2ogr.exe <filename> -init=epsg:4326 -init=world:CH1903
> For each .shp file you have. What is the error you receive? Perhaps
> the
> ogr2ogr.exe isn't in the same folder?
> Jelmer Baas
