ogr2ogr reprojection
Zhonghai Wang
zhonghaiw at GMAIL.COM
Thu May 18 15:35:53 EDT 2006
Hi Jukka,
thanks for your help, I've got it, Yippee!!!!!
I've forgot to specify the -t_srs and s_srs indicators, it's fool...........
thanks again.
zhonghai
On 5/18/06, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> I cannot make a test right now, nor check the documentation, but if I
> remember right with ogr2ogr something like -s_srs "epsg:4323" should work if
> there exists epsg-code for your projection. Similarly -t_srs "epsg: " for
> the target projection.
> -Jukka-
> -----Original Message-----
> From: UMN MapServer Users List on behalf of Zhonghai Wang
> Sent: Thu 18.5.2006 19:54
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] ogr2ogr reprojection
> Hi,
> what you have said works fine, but now something is wrong again with the
> srs
> definition, the error messages on the console are:
> >>>SRS_Def can be a full WKT definition, or a well known definition, i.e.
> epsg:4326 or a file with a WKT definition.
> in the call_convert.bat, I defined like this:
> call convert.bat boundary.shp COUNTRY_region.shp
> call convert.bat forests.shp FOREST_region.shp
> and in the convert.bat file:
> ogr2ogr -init=world:CH1903 -init=epsg:4326 %1 %2
> it seems that the project definition "-init=world:CH1903" is not right,
> but
> I use it also in other mapfiles, and it works well.
> anything wrong?
> zhonghai
> > Hi,
> > I'm sorry about not being clear enough. You must manually edit the
> > "call_convert.bat" by adding the missing parts, that is "call
> convert.bat" in the beginning of each row, and target name at the end of
> the row.
> > Redirecting the file list to batch file prototype is only to help you in
> > creating the working launching bat-file including all your shapefiles.
> > I suggest you to make first make manually a launch file with two or
> three
> > rows only and test with that. When you see that it works you can put all
> > your shapefiles on the list.
> > Regards,
> > -Jukka-
> > ________________________________
> > Lähettäjä: UMN MapServer Users List puolesta: Zhonghai Wang
> > Lähetetty: to 18.5.2006 13:29
> > Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
> > Aihe: Re: [UMN_MAPSERVER-USERS] ogr2ogr reprojection
> > Hi Jukka,
> > I've tried what you said, but it doen't work.
> > the command "dir /b *.shp>call_convert.bat" just simply writes the file
> > path into the call_convert.bat file, and the convert.bat command is
> never
> > be called.
> > after performing "dir /b *.shp>call_convert.bat" I get the file path in
> > the call_convert.bat instead of call convert.bat destination_1 source_1
> > and call convert.bat destination_2 source_2.
> > something is wrong?
> > thanks
> > zhonghai
> > Hi,
> > Another alternative is to make one batch file (.bat) for the
> actual
> > conversion and call it with parameters from another. Like this
> > convert.bat
> > ogr2ogr [-all fixed parameters like -s_srs and -t_srs here] %1 %2
> > call_convert.bat
> > call convert.bat destination_3 source_3
> > etc.
> > Conversion is started by running "call_convert.bat", and
> > "destination_1" and "source_1" will be treated as %1 and %2 by the "
> > convert.bat ", respectively.
> > To start with call_conver.bat you can first insert all your
> > shapefiles there by command
> > dir /b *.shp >call_convert.bat
> > dir /b /s puts there all shapefiles from subdirectories as well.
> > This may be a brutal way but it has some advantages. For example
> > you can add some extra commands to "convert.bat" to be executed after
> > each conversion. This way I use to make log files with time stamps about
> > raster file batch conversions.
> > Regards,
> > -Jukka Rahkonen-
> > Lähettäjä: UMN MapServer Users List puolesta: Jelmer Baas
> > Lähetetty: to 18.5.2006 8:17
> > Zhonghai Wang wrote:
> > > Hi,
> > > I've tried with this batch command, but I failed, because I
> don't
> > know
> > > how to specify the -s_srs and -t_srs parameters, should it be
> > something
> > > like this?
> > >> for %a in (*.shp) do ogr2ogr.exe %a -init=epsg:4326
> > -init=world:CH1903
> > > **init=world:CH1903 is for switzerland, and I am sure that this
> > > projection code is right.
> > yeah, this should do it. Sorry for my short last response though.
> > This should execute
> > ogr2ogr.exe <filename> -init=epsg:4326 -init=world:CH1903
> > For each .shp file you have. What is the error you receive?
> Perhaps
> > the
> > ogr2ogr.exe isn't in the same folder?
> > Jelmer Baas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060518/da8e84e2/attachment.html
