Problem with Mapserver Virtual Spatial Data (ogr)
Christian Wilmes
C.Wilmes at GMX.DE
Fri May 19 02:39:52 EDT 2006
Hi Frank,
thank you very much for your help!
With the line
CONFIG "PGSQL_OGR_FID" "fieldname"
in the Map section everything works very well.
But now I've still got one more question, just an understanding one. I've got testet the "Virtual Spatial Data" with a MySQL Database a few days ago and there everything works well without a line like that. Where could be the reason?
Best Regards
Christian
-------- Original-Nachricht --------
Betreff: Re: [UMN_MAPSERVER-USERS] Problem with Mapserver Virtual Spatial Data (ogr)
Datum: Thu, 18 May 2006 16:55:40 -0400
Von: Frank Warmerdam <warmerdam at POBOX.COM>
An: MAPSERVER-USERS at LISTS.UMN.EDU
> Christian Wilmes wrote:
> > Hello,
> > first of all sorry for cross posting, but I've got no idea where I have
> to
> > search the mistake so I post it to the GDAL and the Mapserver
> Mailinglist.
> > I'm trying to publish a WFS-Server. The Data (only Point-Data) are in a
> > PostgreSQL-Database (no PostGIS!). So the connection to the data is over
> > "Virtual Spatial Data". The getCapabilities and DescribeFeatureType
> request
> > both work very well. Only the GML-Document getting with the getFeature
> > request is not correct. The number of features in the GML-Document are
> > correct too every time, but the features are not in the Bounding Box.
> The
> > features in the GML-Document are always the feature which are on the top
> of
> > the table they come from. Only the number of feature is correct. The MBR
> > (Minimum Boundig Rectangle) on the top of the GML-Document amasingly the
> > correct one. So it don't fit to the features in the document. Testing
> the
> > connection with "ogrinfo" and a Boundig-Box is working correct. If I'm
> > trying to make a WMS-Server with the same Data and the same OGR-file it
> > works very well.
> Christian,
> I believe the problem is that OGR is not successfully identifying a column
> in the table to use as a "feature id". For WFS queries the results are
> fetched in two passes for various historical reasons. The first pass
> results in a fetch of the feature ids of the features, and the second
> pass fetches features by id. Unfortunately, if OGR cannot select a good
> unique feature id column, then it assigns them serially. The first pass
> has the spatial query "in place" so the resulting fids are 1, 2, 3, etc.
> But the second pass does not have the spatial filter in place, so it ends
> up returning the wrong features.
> Ideally you would ensure you have a single integer column setup as a
> primary index for your postgres table. If that is the case it *should*
> get used as the fid.
> If not, you may be able to include the following line in your MAP file
> (in the MAP section, not the layer):
> CONFIG "PGSQL_OGR_FID=fieldname"
> to indicate what fieldname should get used as FID. This should be
> available with GDAL/OGR 1.3.2.
> PS. the much talked about one-pass-query would resolve this problem.
> Good luck,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGF, http://osgeo.org
Bis zu 70% Ihrer Onlinekosten sparen: GMX SmartSurfer!
Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
