Variation in lat/long distances
Kelly Koehn
kkoehn at ASPIREDILLUSION.COM
Sun May 21 01:41:25 EDT 2006
I'm working with Level III data pulled from their FTP site (in the process
of setting up a NOAAPORT system though). It all started with a desire to
learn how to read it and then it just built into something more. I don't
use anything to process the files and read them in with PHP and decode
everything bit by bit :)
I've been doing some reading and I guess calculating the distance over
longitudes are somewhat more complicated because the distances change as the
latitude changes. Anyone know how to calculate that?
Kelly
----- Original Message -----
To: "Kelly Koehn" <kkoehn at ASPIREDILLUSION.COM>
Sent: Sunday, May 21, 2006 12:36 AM
Subject: [SPAM] Re: [UMN_MAPSERVER-USERS] Variation in lat/long distances
>I suspect you and I need to talk. Are you using LEvel II or Level III
>data? We're doing a fair bit w/ Nexrad data and using Gempak to create the
>imagery for display.
> gerry
> Kelly Koehn wrote:
>> I'm working with some NEXRAD radar data and reading the binary data and
>> drawing it on a map. I'm using Mapserver on the backend to produce the
>> map. What i'm basically doing is calculating 124 nautical miles (142
>> statute miles) from a center point (the radar) and then drawing my radar
>> data on top of that. I found this nifty little formula on the net that
>> supposedly converts nautical miles to statute miles but it doesn't seem
>> to really be working as expected.
>> The formula is as follows:
>> (((sm * 0.0254) * 63360) / 1852) / 60 = nm
>> where sm = statute miles and nm = nautical miles
>> At that point I take the value that I receive above and do the
>> appropriate + or - calclations from the radar's location (lat/long) and
>> get the extent for the map which is pushed through the URL. What I've
>> noticed is that the latitude seems to be correct but the longitude always
>> falls short 20 or 30 miles from what it should be (almost cutting off a
>> county on either side). Has anyone else experienced this? I've checked
>> the x and y distances and they are both equal. I'm producing a 460 x 460
>> GIF image that uses the nationalatlas.gov SHP files. I'm using the
>> county and states sets.
>> I can post my .map files and anything else that might be helpful
>> (including sample images).
>> Thanks
>> Kelly Koehn
> Gerry Creager -- gerry.creager at tamu.edu
> Texas Mesonet -- AATLT, Texas A&M University Cell: 979.229.5301 Office:
> 979.458.4020 FAX 979.862.3983
> MAIL: AATLT, 3139 TAMU
> Physical: 1700 Research Parkway, Suite 160,
> College Station, TX 77843-3139
