Min / nMake/ makefile.vc
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Sun May 21 11:35:11 EDT 2006
if you use the MS4W package, it has flash capabilities (OUTPUT=SWF). You
don't need to compile Mapserver yourself then.
http://www.maptools.org/ms4w/index.phtml
c:\ms4w\Apache\cgi-bin>mapserv -v
MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPO
RTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPO
RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SH
APEFILE DEBUG=MSDEBUG
Best regards,
Bart
Andrew Timmins wrote:
> Hello All!
> I am currently new to Map server but looking at using it and have some
> questions.
> I am looking at using Flash to help develop my application and map
> server seems to have this capability. I have done some readings and
> have found a library called MING 0.2a that will allow this to happen.
> I need some help installing this Lib.
> I am running Map server and php on a Windows desktop right now.
> Is this a library for php ? or is this for Map Server?
> I have found this documentation on how to get started but i am stuck..
> http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html
> Just a bit down th page its says to do the following
> nmake –f makefile.vc <http://makefile.vc>
> What is nmake? and how to i run this? (Dos ?)
> Drew
OSGIS, Open Source GIS
http://www.osgis.nl
