RV: PostGis Join, wont show up map
Fuchs Juan Carlos
jfuch at INDEC.MECON.GOV.AR
Mon May 22 14:54:19 EDT 2006
> Hi Folks!
> Im struggling with a weird problem
> Here the scenario:
> Linux, HostGis 10 buildup, Mapserver 4.6, Postgres 8. up
> address to try out http://200.32.100.173
> from the Hostgis menu, the PostGres JOIN failed option.
> from the map file
> MAP # Abrir mapa
> DEBUG ON
> NAME MapaDinamico
> STATUS ON
> SIZE 604 604
> EXTENT 1688948.00 3785439.00 5996706.00 7725558.00
> UNITS METERS
> DATAPATTERN "/var/www/mapdata/"
> SHAPEPATH "/var/www/mapdata/tiles/"
> FONTSET "/var/www/mapdata/fonts.inc"
> IMAGECOLOR 255 255 255
> IMAGETYPE GIF
> OUTPUTFORMAT
> NAME GIF
> DRIVER "GD/GIF"
> FORMATOPTION "INTERLACE=ON"
> MIMETYPE "image/gif"
> IMAGEMODE PC256
> END
> # web interface definition
> WEB
> # the template for browsing mode
> TEMPLATE "/var/www/htdocs/example/main.html"
> IMAGEPATH "/var/www/mapdata/www/temp/"
> IMAGEURL "/temp/"
> LOG Mapserverlog.txt
> END
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE truetype
> FONT Vera
> SIZE 7
> COLOR 0 0 0
> END
> STATUS ON
> END
> PROJECTION
> "init=epsg:22193"
> END
> the layer that works ...
> #************** PostGresSQL Radios Rurales FAJA 3 *****************
> LAYER
> CONNECTIONTYPE postgis
> NAME "delpostgis-gisdata-sql"
> CONNECTION "user=myuser password=mypassword dbname=mydb
> host=localhost"
> DATA "the_geom FROM paisradp"
> STATUS OFF
> TYPE POLYGON
> MAXSCALE 25000000
> MINSCALE 100
> PROJECTION
> "init=epsg:22193"
> END
> CLASS
> STYLE
> RANGEITEM "symbol"
> DATARANGE 1 6
> COLORRANGE 255 255 178 189 0 38
> END
> END
> END
> #**************FIN PostGresSQL Radios Rurales FAJA 3 **************
> the layer that dont work ...
> #************** PostGresSQL Pob Total Radios Rurales FAJA 3 *******
> LAYER
> NAME "delpostgis-mapas-mymap-sql"
> host=localhost"
> DATA "SELECT a.the_geom, a.gid, a.tpp_t, a.idcompuesto FROM
> (SELECT p.idcompuesto, p.tpp_t, m.*
> FROM prov01 m LEFT JOIN
> poblacion_provincia p
> ON p.idcompuesto = m.prov
> WHERE p.idcompuesto <> '02')
> AS algo a
> USING UNIQUE gid
> USING SRID=22193"
> STATUS OFF
> TYPE POLYGON
> PROJECTION
> "init=epsg:22193"
> END
> CLASS
> STYLE
> RANGEITEM "algo.tpp_t"
> DATARANGE 99356 13708902 #1 40000
> OUTLINECOLOR 0 0 0
> #COLOR 200 200 200
> END
> END
> END
> #**************FIN PostGresSQL Pob Tot Radios Rurales FAJA 3 ******
> end # end of layer
> the log from MapServer
> Mon May 22 15:29:37 2006,
> 9930,
> 172.26.68.166,
> MapaDinamico,
> 4,
> 1434001.464365 3784641.243572 6251652.535635 7726355.756428,
> -1.000000 -1.000000,
> delpostgis-mapas-mymap-sql pais_prov ,
> normal execution
> ¿¿¿ but the map does not show up ???
> May some one give me a hand with this, please !!!
> Thanks in advance
> Juan Carlos Fuchs.
