imagemap not following bounding box
Adrian Versteegen
A.Versteegen at BOM.GOV.AU
Mon May 22 21:35:33 EDT 2006
I am trying to produce an imagemap using mapserver 4.8.3 cgi. The issue
is that I can't seem to make it respect the bounding box or image size
specified in the url request.
When trying the shp2img utility with the -e flag, the extents are obeyed
and the html is produced for the restricted area.
The image and the imagemap are produced by a perl script calling the
mapserv executable with the following commands:
http://my_url/mapserver/mapserv?map="/mapserver/simple.map&version=1.1.1&service=WMS&request=GetMap&layers=${layers}&bbox=${bbox}&height=${height}&width=${width}
http://my_url/mapserver/mapserv?map="/mapserver/simple.map&qlayer=name_tag&mode=nquery&searchmap=true&bbox=${bbox}&height=${height}&width=${width}
The aim being that with the bbox, height and width variables we can
alter the image to suit a particular client. This works well with the
image but the imagemap insists on sticking to the size and extent from
the original map file.
How do we make the imagemap use the bounding box and size restrictions?
Or am I going about it the hard way and should be using mapscript?
Thanks,
Adrian
Extract of map file:
MAP
NAME "WEATHER"
SIZE 600 600
UNITS kilometers
EXTENT 0 0 5232 5965
SHAPEPATH "/shp/"
FONTSET "fonts/font.list"
SYMBOLSET "symbols/symbols.dat"
IMAGECOLOR 172 212 232
WEB
TEMPLATE "/htdocs/aust.html"
IMAGEPATH "/temp/"
IMAGEURL "/temp/"
END
PROJECTION
"proj=merc"
# coordinates are of lower left corner
"lon_0=111e"
"y_0=6075085" # 48.0s
"units=km"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
END
OUTPUTFORMAT
NAME imagemap
DRIVER "imagemap"
MIMETYPE "text/html"
END
LAYER
NAME name_tag
STATUS on
DATA 'latest_obs'
PROJECTION
"proj=latlong"
END
TYPE point
LABELITEM "Name"
TEMPLATE "bodytemplate.html"
HEADER "imapheader.html"
FOOTER "imapfooter.html"
CLASS
COLOR -1 -1 -1
LABEL
POSITION AUTO
OFFSET 1 1
TYPE TRUETYPE
FONT verdana
ANTIALIAS true
SIZE 8
COLOR 0 0 0
END
END
END # end layer
<other layer details....>
END # map file
bodytemplate.html:
<area shape="circle" coords="[shpxy precision=0 proj=image yf=",7"
xf=","]" href="target_[Name].shtml" title="[Name]" alt="[Name]">
