label___scale confusion, or, Can I find out the scale?
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Tue May 23 04:25:33 EDT 2006
Being not a label specialist, either, here is one whole layer that worked just fine for me when I made my trial with LABELMAXSCALE.
Regards,
-Jukka Rahkonen-
LAYER
NAME "siat"
STATUS ON
DATA "AIvalvonta.qix"
TYPE POINT
CLASSITEM "ELAINLAJI"
UNITS METERS
SIZEUNITS METERS
SYMBOLSCALE 5
LABELITEM "TKTUNNUS"
LABELMAXSCALE 100000
TOLERANCE 1
TOLERANCEUNITS PIXELS
FILTER ([ELAINLAJI] =03)
FILTERITEM "ELAINLAJI"
MAXFEATURES 10000
TEMPLATE "../../../../../../..//ms101/data/query.html"
METADATA
"wms_title" "siat"
END
PROJECTION
END
CLASS
NAME "siat"
LABEL
TYPE BITMAP
SIZE MEDIUM
POSITION AUTO
COLOR 150 0 200
END
STYLE
SYMBOL 7
COLOR 150 0 200
OUTLINECOLOR 0 0 0
MINSIZE 10
MAXSIZE 10
END
END
END
Lähettäjä: UMN MapServer Users List puolesta: Ben Madin
Lähetetty: ti 23.5.2006 4:38
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: [UMN_MAPSERVER-USERS] label___scale confusion, or, Can I find out the scale?
Hopefully a quick one, but I am struggling with getting labels to
display when zoomed in.
the mapscript seems to be working OK, as the output mapfile looks OK,
but the labels choose to either display or not throughout the
resulting map whether I zoom in or out. Ignore the actual values as I
have tried quite a range in both orders!
LABELITEM "ADMIN1"
LABELMAXSCALE 5e+006
LABELMINSCALE 10
METADATA
END
NAME "default_layer"
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
My questions are :
1. can I find the actual value of the "scale" and display it on the
screen (realising that it has no value to the user) (ideally in php-
mapscript)
2. how does reprojecting the map affect the scale, and if we
reproject, for which projection do we have to specify when the labels
are added.
(to expand on 2, the map is ulitmately reprojected to orthographic)
cheers
Ben
Ben Madin
t/f: 08 9192 5535
m: 0448 887 220
ben at remoteinformation.com.au
