[UMN_MAPSERVER-USERS] mapfile configuration problem --
MapServer for IIS
Fortin,Nicolas [SteFoy]
nicolas.fortin at EC.GC.CA
Wed May 24 11:25:22 EDT 2006
Hi
Did you enabled CGI extensions in IIS? If not, you can do this in the IIS Manager under the Web Services Extensions folder.
Nicolas
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Zhonghai Wang
Envoyé : 24 mai 2006 11:19
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] mapfile configuration problem -- MapServer for IIS
thanks guys, after I set the imageurl as http://localhost/ms_tmp, MapServer works well again. URL should be a real URL, that's it.
I am trying now to install MapServer with IIS 6 on Windows 2003, the same configurations as on WinXP do not work on Windows 2003 any more, and I can not even open the mapserver initial page.
I've searched in our list achieves, somebody says that there may be some problems with IIS 6, but I still can not figure out where the problem is.
could anyone give me clues?
thanks for any tips.
zhonghai
On 5/24/06, Till Adams <adams at terrestris.de> wrote:
Zhongai,
your imageurl should be an URL, not a path, e.g.
Leave the last slash in your imagepath. It is also ok only to use
forward slashes.
Cheers, Till
Zhonghai Wang schrieb:
> Hi guys,
> I am trying to install MapServer with IIS, and I've done all the
> things following this doc:
> http://mapserver.gis.umn.edu/docs/howto/setupiis/?searchterm=IIS
> but there are some problems with the mapfile path configuration, I set
> the paths like this:
> 1. IMAGEPATH "C:\ms4w\tmp\ms_tmp\"
> IMAGEURL "C:\ms4w\tmp\ms_tmp\"
> 2. TEMPLATE "/ms4w/apps/Demo/tmps/demomap.html"
> 3. LOG "C:/ms4w/LogFiles/MapServer.log" -- this one works well.
> 4. IMAGE "C:/ms4w/apps/Demo/images/KeyMap.gif" -- for the reference
> map (in the Reference object)
> the IMAGEURL and IMAGE paths do not work, because the generated map
> images, scalebar and reference map are already there,
> and the browser can not find and display them. did I made some
> mistakes when I set the paths?
> P.S: in the Internet Services Manager I set the ms_tmp and tmp folder
> readable and writable.
> thanks for any tips
> zhonghai
* released: AmeiN! ArcMap-Export-2-UMN *
* LiveLinux 'WebGIS on CD' *
* http://www.terrestris.de *
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060524/0809b8ee/attachment.html
