mapfile configuration problem -- MapServer for IIS
Zhonghai Wang
zhonghaiw at GMAIL.COM
Wed May 24 11:19:01 EDT 2006
thanks guys, after I set the imageurl as http://localhost/ms_tmp, MapServer
works well again. URL should be a real URL, that's it.
I am trying now to install MapServer with IIS 6 on Windows 2003, the same
configurations as on WinXP do not work on Windows 2003 any more, and I can
not even open the mapserver initial page.
I've searched in our list achieves, somebody says that there may be some
problems with IIS 6, but I still can not figure out where the problem is.
could anyone give me clues?
thanks for any tips.
zhonghai
On 5/24/06, Till Adams <adams at terrestris.de> wrote:
> Zhongai,
> your imageurl should be an URL, not a path, e.g.
> Leave the last slash in your imagepath. It is also ok only to use
> forward slashes.
> Cheers, Till
> Zhonghai Wang schrieb:
> > Hi guys,
> > I am trying to install MapServer with IIS, and I've done all the
> > things following this doc:
> > http://mapserver.gis.umn.edu/docs/howto/setupiis/?searchterm=IIS
> > but there are some problems with the mapfile path configuration, I set
> > the paths like this:
> > 1. IMAGEPATH "C:\ms4w\tmp\ms_tmp\"
> > IMAGEURL "C:\ms4w\tmp\ms_tmp\"
> > 2. TEMPLATE "/ms4w/apps/Demo/tmps/demomap.html"
> > 3. LOG "C:/ms4w/LogFiles/MapServer.log" -- this one works well.
> > 4. IMAGE "C:/ms4w/apps/Demo/images/KeyMap.gif" -- for the reference
> > map (in the Reference object)
> > the IMAGEURL and IMAGE paths do not work, because the generated map
> > images, scalebar and reference map are already there,
> > and the browser can not find and display them. did I made some
> > mistakes when I set the paths?
> > P.S: in the Internet Services Manager I set the ms_tmp and tmp folder
> > readable and writable.
> > thanks for any tips
> > zhonghai
> * released: AmeiN! ArcMap-Export-2-UMN *
> * LiveLinux 'WebGIS on CD' *
> * http://www.terrestris.de *
> Dipl. Geogr. Till Adams
> terrestris, H. Paulsen& T. Adams GbR
> Siemensstr. 8 * 53121 Bonn
> Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
> info at terrestris.de * http://www.terrestris.de
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060524/439c97ed/attachment.html
