EXTENSION in WMS-Mapfile using WFS
Christian Wilmes
C.Wilmes at GMX.DE
Wed May 24 11:28:01 EDT 2006
The getCapabilies Document:
<?xml version="1.0" encoding="ISO-8859-1" ?>
- <WFS_Capabilities version="1.0.0" updateSequence="0" xmlns="http://www.opengis.net/wfs" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengeospatial.net/wfs/1.0.0/WFS-capabilities.xsd">
- <!-- MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
- <Service>
<Name>MapServer WFS</Name>
<Title>WFS Server</Title>
<OnlineResource>http://127.0.0.1/cgi-bin/mapserv.exe?</OnlineResource>
</Service>
- <Capability>
- <Request>
- <GetCapabilities>
- <DCPType>
- <HTTP>
<Get onlineResource="http://127.0.0.1/cgi-bin/mapserv.exe?" />
</HTTP>
</DCPType>
- <DCPType>
- <HTTP>
<Post onlineResource="http://127.0.0.1/cgi-bin/mapserv.exe?" />
</HTTP>
</DCPType>
</GetCapabilities>
- <DescribeFeatureType>
- <SchemaDescriptionLanguage>
<XMLSCHEMA />
<SFE_XMLSCHEMA />
</SchemaDescriptionLanguage>
- <DCPType>
- <HTTP>
</HTTP>
</DCPType>
- <DCPType>
- <HTTP>
</HTTP>
</DCPType>
</DescribeFeatureType>
- <GetFeature>
- <ResultFormat>
<GML2 />
<GML3 />
</ResultFormat>
- <DCPType>
- <HTTP>
</HTTP>
</DCPType>
- <DCPType>
- <HTTP>
</HTTP>
</DCPType>
</GetFeature>
</Request>
</Capability>
- <FeatureTypeList>
- <Operations>
<Query />
</Operations>
- <FeatureType>
<Name>myWFS</Name>
<Title>myWFS</Title>
<SRS>EPSG:31467</SRS>
<LatLongBoundingBox minx="7.50295" miny="52.3333" maxx="7.54897" maxy="52.3698" />
</FeatureType>
</FeatureTypeList>
- <ogc:Filter_Capabilities>
- <ogc:Spatial_Capabilities>
- <ogc:Spatial_Operators>
<ogc:Intersect />
<ogc:DWithin />
<ogc:BBOX />
</ogc:Spatial_Operators>
</ogc:Spatial_Capabilities>
- <ogc:Scalar_Capabilities>
<ogc:Logical_Operators />
- <ogc:Comparison_Operators>
<ogc:Simple_Comparisons />
<ogc:Like />
<ogc:Between />
</ogc:Comparison_Operators>
</ogc:Scalar_Capabilities>
</ogc:Filter_Capabilities>
</WFS_Capabilities>
The DescribeFeature Document:
- <schema targetNamespace="http://mapserver.gis.umn.edu/mapserver" xmlns:ms="http://mapserver.gis.umn.edu/mapserver" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://www.w3.org/2001/XMLSchema" xmlns:gml="http://www.opengis.net/gml" elementFormDefault="qualified" version="0.1">
<import namespace="http://www.opengis.net/gml" schemaLocation="http://schemas.opengeospatial.net/gml/2.1.2/feature.xsd" />
<element name="myWFS" type="ms:myWFSType" substitutionGroup="gml:_Feature" />
- <complexType name="myWFSType">
- <complexContent>
- <extension base="gml:AbstractFeatureType">
- <sequence>
<element name="msGeometry" type="gml:GeometryPropertyType" minOccurs="0" maxOccurs="1" />
<element name="angle" type="string" />
<element name="len" type="string" />
<element name="o_cendeg" type="string" />
<element name="o_cendist" type="string" />
<element name="o_clock" type="string" />
<element name="o_maxdeg" type="string" />
<element name="o_maxdist" type="string" />
<element name="o_mindeg" type="string" />
<element name="o_mindist" type="string" />
<element name="od" type="string" />
<element name="top" type="string" />
<element name="type" type="string" />
<element name="wid" type="string" />
<element name="wl" type="string" />
<element name="wt" type="string" />
<element name="x" type="string" />
<element name="y" type="string" />
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
Christian
> -------- Original-Nachricht --------
> Datum: Wed, 24 May 2006 11:04:32 -0400
> Von: Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca>
> An: Christian Wilmes <C.Wilmes at GMX.DE>, <MAPSERVER-USERS at LISTS.UMN.EDU>
> Betreff: RE: [UMN_MAPSERVER-USERS] EXTENSION in WMS-Mapfile using WFS
> Sounds like a server issue. What happens if you try to access the
> server "by hand", i.e.
> http://URL-to-your-WFS?version=1.0.0&service=WFS&request=GetCapabilities
> http://URL-to-your-WFS?version=1.0.0&service=WFS&request=DescribeFeature
> Type
> Where URL-to-your-WFS is the CONNECTION directive.
> ..Tom
> > -----Original Message-----
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Christian Wilmes
> > Sent: Wednesday, May 24, 2006 3:43 AM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-USERS] EXTENSION in WMS-Mapfile using WFS
> > > Hi All,
> > I'm writing a WMS-Mapscript. For one Layer I'm getting the
> > data from a WFS, which is set up by me too. Now I want to set
> > an Extension in the Mapscript of the WMS like that:
> > > LAYER
> > NAME "WFS"
> > TYPE POINT
> > STATUS ON
> > DEBUG ON
> > CONNECTIONTYPE WFS
> > CONNECTION "http://localhost/cgi-bin/mapserv.exe?"
> > METADATA
> > "wfs_typename" "myWFS"
> > "wfs_version" "1.0.0"
> > "wfs_request_method" "GET"
> > END
> > > PROJECTION
> > "init=EPSG:31467"
> > END
> > > CLASS
> > NAME test
> > EXPRESSION ([test] > 1)
> > SYMBOL "Punkt"
> > SIZE 10
> > COLOR 255 0 0
> > END
> > END
> > > Testing the WMS sends the following error:
> > <ServiceException>msDrawMap(): Image handling error. Failed
> > to draw layer named 'RosoftWFS'. msOGRLayerInitItemInfo():
> > OGR error. Invalid Field name: len</ServiceException>
> > > So what could be the reason of the error?
> > Best Regards
> > Christian
> > > Bis zu 70% Ihrer Onlinekosten sparen: GMX SmartSurfer!
> > Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
