Help needed with compiling postgre sql with mapserver
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Thu May 25 03:07:09 EDT 2006
Did you install the Platform SDK form Microsoft? See also:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1251
Best regards,
Bart
rock well wrote: Hi fleuren the reason i dont want to use hobus
mapserver is i guess it doesnt have the support for mrsid format and
also sde libraries which i already have configured using the
conventional mapserver. i was able to get rid of these error and was
able to create the libpadll.lib but i wasnt able to create the libpq.dll
file as it gave me the following error
> libpq.lib(fe-connect.obj) : error LNK2001: unresolved external symbol
> _SHGetFolderpath
> .\Release\libpq.dll : fatal error LNK1120: 1 unresolved externals
> and the execution stopped .....
> i guess someone might have encountered this problem, if so can you
> give me some tips to solve it .....
> If you dont mind fleuren can you send me the libpq.dll as an
> attachment as thats the only file i need to get going ....
> Thanks a lot for your help ....
> kris
> */Huub Fleuren <hfl at home.nl>/* wrote:
> Hi Kris,
> I did feel lucky that the compile did not end with the word Stop.
> I'm afraid experience problems like this now with the ECW library.
> Maybe try the very rich .\bin directory of
> http://hobu.stat.iastate.edu/mapserver/build_output/mapserver-4.8.3-msvc71-build-kit.zip
> this is a set for msvc7, so probably, issues on vc6
> Regards, Huub
> rock well schreef:
> > Thanks for your reply fleuren, yes i did the same way you told but
> > still it give the following errors
> > LINK : fatal error LNK1181: cannot open input file "shfolder.lib"
> > NMAKE : fatal error U1077: 'link.exe' : return code '0x49d'
> > Do you know why we get these errors, or else all we need is i guess
> > the libpqdll.lib and some dlls right, if anything doesnt work
> can you
> > send me those dlls.
> > Thanks verymuch for your help and time ...
> > kris
> > */Huub Fleuren /* wrote:
> > Hi Rock,
> > i recently compiled postgreql-8.1.3 with vc6sp4 and
> > 5.2.3790.2075.51.PlatformSDK_Svr2003R2_rtm.img
> > (install from virtual CD)
> > first vcvars32
> > then setenv
> > then nmake /f win32.mak
> > after a failure you always do nmake /f win32.mak clean
> > Regards, Huub
> > rock well schreef:
> > > Hi all, i am trying to compile mapserver with postgre sql
> > support. I
> > > found this documentation in the mapserver website
> > > http://mapserver.gis.umn.edu/docs/howto/win32_compiling
> > > I downloaded the MS platform sdk and installed it, when i try to
> > run
> > > the win32.mak file in the libpq directory it still says
> > > the shfolder.lib does exist in the the default MS platform sdk
> > folder,
> > > do i have to change something or am i doing something wrong ...
> > > Thanks for your time ....
> > > kris
> > > Blab-away for as little as 1¢/min. Make PC-to-Phone Calls
> > > using Yahoo! Messenger with Voice.
> > Love cheap thrills? Enjoy PC-to-Phone calls to 30+ countries
> > for just 2¢/min with Yahoo! Messenger with Voice.
> Ring'em or ping'em. Make PC-to-phone calls as low as 1¢/min
> <http://us.rd.yahoo.com/mail_us/taglines/postman11/*http://us.rd.yahoo.com/evt=39666/*http://voice.yahoo.com>
OSGIS, Open Source GIS
http://www.osgis.nl
