Help needed with compiling postgre sql with mapserver
rock well
rockwell_001 at YAHOO.COM
Thu May 25 11:37:09 EDT 2006
yes i did install the platform sdk and there is also an shfolder.lib file in the sdk folder, though it gives me an error .....
Thanks for your reply .....
"Bart van den Eijnden (OSGIS)" <bartvde at XS4ALL.NL> wrote:
Did you install the Platform SDK form Microsoft? See also:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1251
Best regards,
Bart
rock well wrote: Hi fleuren the reason i dont want to use hobus
mapserver is i guess it doesnt have the support for mrsid format and
also sde libraries which i already have configured using the
conventional mapserver. i was able to get rid of these error and was
able to create the libpadll.lib but i wasnt able to create the libpq.dll
file as it gave me the following error
> libpq.lib(fe-connect.obj) : error LNK2001: unresolved external symbol
> _SHGetFolderpath
> .\Release\libpq.dll : fatal error LNK1120: 1 unresolved externals
> and the execution stopped .....
> i guess someone might have encountered this problem, if so can you
> give me some tips to solve it .....
> If you dont mind fleuren can you send me the libpq.dll as an
> attachment as thats the only file i need to get going ....
> Thanks a lot for your help ....
> kris
> */Huub Fleuren /* wrote:
> Hi Kris,
> I did feel lucky that the compile did not end with the word Stop.
> I'm afraid experience problems like this now with the ECW library.
> Maybe try the very rich .\bin directory of
> http://hobu.stat.iastate.edu/mapserver/build_output/mapserver-4.8.3-msvc71-build-kit.zip
> this is a set for msvc7, so probably, issues on vc6
> Regards, Huub
> rock well schreef:
> > Thanks for your reply fleuren, yes i did the same way you told but
> > still it give the following errors
> > LINK : fatal error LNK1181: cannot open input file "shfolder.lib"
> > NMAKE : fatal error U1077: 'link.exe' : return code '0x49d'
> > Do you know why we get these errors, or else all we need is i guess
> > the libpqdll.lib and some dlls right, if anything doesnt work
> can you
> > send me those dlls.
> > Thanks verymuch for your help and time ...
> > kris
> > Hi Rock,
> > i recently compiled postgreql-8.1.3 with vc6sp4 and
> > 5.2.3790.2075.51.PlatformSDK_Svr2003R2_rtm.img
> > (install from virtual CD)
> > first vcvars32
> > then setenv
> > then nmake /f win32.mak
> > after a failure you always do nmake /f win32.mak clean
> > Regards, Huub
> > rock well schreef:
> > > Hi all, i am trying to compile mapserver with postgre sql
> > support. I
> > > found this documentation in the mapserver website
> > > http://mapserver.gis.umn.edu/docs/howto/win32_compiling
> > > I downloaded the MS platform sdk and installed it, when i try to
> > run
> > > the win32.mak file in the libpq directory it still says
> > > the shfolder.lib does exist in the the default MS platform sdk
> > folder,
> > > do i have to change something or am i doing something wrong ...
> > > Thanks for your time ....
> > > kris
> > > Blab-away for as little as 1¢/min. Make PC-to-Phone Calls
> > > using Yahoo! Messenger with Voice.
> > Love cheap thrills? Enjoy PC-to-Phone calls to 30+ countries
> > for just 2¢/min with Yahoo! Messenger with Voice.
> Ring'em or ping'em. Make PC-to-phone calls as low as 1¢/min
OSGIS, Open Source GIS
http://www.osgis.nl
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail Beta.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060525/8c7eb4c3/attachment.html
