temp file names not unique
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Mon May 29 11:31:42 EDT 2006
Hi Frank,
apparently the php code does not use the tmp file name functions from
maputil.c, at least that is what I could make up out of the following
bug report:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1322
which was the one I was looking for earlier on.
It is hard to make a testcase for this kind of behaviour. If someone is
able to make a patch, I would be happy to test it in our environment
ofcourse.
Best regards,
Bart
Frank Warmerdam wrote:
> Bart van den Eijnden (OSGIS) wrote:
>> Hi list,
>> using Mapscript 4.8.3 we have encountered a problem with the
>> uniqueness of
>> the filenames of scalebar images saved to the ms_tmp directory
>> (filenames
>> are being reused, resulting in problems with the browser cache). We are
>> running PHP 4.3.11 as an Apache module.
>> What is the status of this problem? I do remember a bugzilla entry about
>> this by Bill Binko and Daniel Morissette, but I am unable to find it.
> Bart,
> Based on an examination of the code, I don't see how this could be
> happening,
> but it has been reliably reported. Is it possible for you to construct a
> case PHP script that demonstrates the problem? What do the temp
> filenames
> look like?
> Looking at the maputil.c log messages, I suspect bug 1312 is the one in
> question.
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1312
> Best regards,
OSGIS, Open Source GIS
http://www.osgis.nl
