Make points on a map clickable + use criteria from MySQL
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue May 30 12:51:21 EDT 2006
One way to do this is with an imagemap that calls a javascript function
it add the item to an array. Then you can fetch and use the array of
items for whatever later.
-Steve W
Sarah Parrott wrote:
> Hi,
> Is there a way to make points on a map clickable? Basically I want the
> user to be able to look at the map and then select a subset of the
> points on it by clicking on them and then use this 'list' of points
> somewhere else. The points are stored in a shapefile which is displayed
> on top of a raster layer.
> Also, with the same points in the shapefile, can I display them
> differently depending on a value in a mysql database? Each user will
> have their own data about that point - mainly whether or not they have
> been there - and I want to be able to show points they have visited in a
> different way to points they haven't.
> Thanks!
> Sparrott :)
