ZOOM TO A SELECTED OBJECT
J. Parapar
listario at GMAIL.COM
Tue May 30 15:09:17 EDT 2006
Hi Toni
You can use the itemquery mode to select the municipality and the
mapxy parameter to set the map extent, mapxy=shape set map extent to
the extent of the selected shape. See also the buffer and scale
parameters.
Hope this helps.
Best regards,
Jorge
2006/5/30, toni hernández <toni at sigte.udg.es>:
> Hi,
> I have a layer of municipalities boundaries (SHP file with polygons)
> How can I zoom to a municipality selected for the user from an HTML form?
> Ex. Zoom to a municpality called "SALT".
> Maybe changing the map file dynamically?
> I have been reading about filter and fitleritem but I do not see how can
> make a zoom to a particular municpality.
> thanks
